in your plugins i'm getting access denied.
i am always on default(and it has admin access)
the only thing i did was disable all other user access...
Even if i put it back to any like it was it doesnt work... and you can't never select default like it says
this is in the devices :
User Access: Users that have access:
Admin Users
i am logged in local under default(admin+local)
all other plugins from other people works normal..
regards
The Web Page You Were Trying To Access Is Restricted To Authorized Users ONLY
This page is displayed if the credentials passed to the web server do not match the credentials required to access this web page.
If you know the default user should have access, then ask your HomeSeer Administrator to check the UltraLog3 plug-in options page to make sure the roles assigned to the default user allow access to this web page.
Admin Users
regards
