I've noted that whenever I restart the process on the pi, a new set of devices is created in Homeseer - is this expected behavior or am I doing something wrong? I'm not doing anything to shut down the process on the pi first, just a sudo reboot....
Devices keep getting recreated?
no this is not the expected behavior, however I can reproduce this problem. When the remote plugin is automatically started when the Pi boots, I get the following error in the log, which means the plugin cannot check if the devices already exists, as a consequence devices are wrongly recreated:
Code:Dec-27 9:46:21 AM RaspberryIO DEBUG Stack: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IHSApplication:GetDeviceEnumerator () at HSPI_RaspberryIO.RaspberryPiApp.CreateHSDevices () <0x73c1a5b0 + 0x00043> in :0 Dec-27 9:46:21 AM RaspberryIO ERROR CreateHSDevices: Object reference not set to an instance of an object
What is strange is that when the plugin is manually started from the command line, everything works fine.
I will investigate more and try to fix it.
I see those messages - here is my log from the latest pi reboot
Dec-27 20:50:32 RaspberryIO DEBUG Stack: at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr) at (wrapper remoting-invoke) HomeSeerAPI.IHSApplication:GetDeviceEnumerator () at HSPI_RaspberryIO.RaspberryPiApp.CreateHSDevices () <0x74a110b0 + 0x00043> in :0
Dec-27 20:50:32 RaspberryIO ERROR CreateHSDevices: Object reference not set to an instance of an object
Dec-27 20:50:28 RaspberryIO INFO Serial number: 0000000091c0d81c
Dec-27 20:50:28 RaspberryIO INFO Firmware rev10494082, board model B3 (Raspberry Pi 3 Model B)
Dec-27 20:50:28 RaspberryIO INFO Raspberry Pi running on Bcm2709 processor
Dec-27 20:50:27 RaspberryIO INFO RaspberryIO version 3.0.0.4
Dec-27 20:50:27 Info Plugin RaspberryIO with instance driveway has connected. IP:192.168.250.56:37422
please try version 3.0.0.5 available here as well as from the remote package: https://www.dropbox.com/s/7spvkqbtj9...ll_3-0-0-5.zip
