I am evaluating this plugin and am using the Smartbridge Pro 2. The connection is good and things seem to get added when I add them through the config page. I'm trying to simplify things so that it's easy for my wife and I to use so I just added the light itself and not the pico remote to Homeseer. I can go into the HS Touch app on Android and trigger the light on and off and it responds accordingly. The issue is that as soon as it triggers, it will force close the app and I have to relaunch the HS Touch app.
Also a question about preference. Would you recommend that I add the Pico remote that's associated with the light into HS so that we can control the light via that instead of the light directly? I'm just curious how most people would handle that setup normally.
