I use the Insteon ISY and the Elk M1 to control my lighting. I find it easier to use the ISY software to manage the device names and locations by following a simply naming format. I use a 4 character code for the location followed by a dash followed by the device name. As an example, the master bedroom overhead light is named "BdrM-Overhead" in the ISY.
Getting the lighting data into HomeSeer using the Elk M1 HSPI is a multiple step process.
I hope someone finds this information helpful.
Ultrajones
- Export the lighting to an XML file using the Insteon ISY software.
- Import the Insteon lighting data into the Elk M1 using the Elk RP software.
- Confirm the number of devices you have defined in the Elk M1 matches UltraM1G > Options > Defined Elk M1G Configuration > Lighting
- From HomeSeer, refresh the Elk M1 configuration from UltraM1G > Status > Reload Data. The reload may take up to 5 minutes on a slow HomeSeer PC.
- Use the script below to programmatically update the location based on the imported device names.
Sub Main(ByVal parm As Object) Dim IFACE_NAME As String = "UltraM1G" Dim Locations As New System.Collections.Hashtable Locations.Add("Bsmt", "Basement") Locations.Add("BdmK", "Bedroom [One]") Locations.Add("BdmR", "Bedroom [Two]") Locations.Add("BdmM", "Bedroom [Master]") Locations.Add("Brdg", "Bridge") Locations.Add("Den", "Den") Locations.Add("DnRm", "Dining Room") Locations.Add("FmRm", "Family Room") Locations.Add("Entr", "Front Entrance") Locations.Add("Garage", "Garage") Locations.Add("Hall", "Hall") Locations.Add("Ktch", "Kitchen") Locations.Add("Outs", "Outside") Try ' ' ' Run though all the HomeSeer devices ' Dim DevEnum As Object = hs.GetDeviceEnumerator If Not DevEnum Is Nothing Then Do While Not DevEnum.Finished Dim objDevice As Object = DevEnum.GetNext If Not objDevice Is Nothing Then If objDevice.interface = IFACE_NAME And objDevice.dev_type_string = "Elk M1 Lighting" Then Dim strDeviceName As String = objDevice.Name For Each strKey As String In Locations.Keys If strDeviceName.Contains(strKey & "-") Then objDevice.location = Locations(strKey) objDevice.location2 = "Elk M1 Ligthing" Exit For End If Next End If End If Loop End If Catch pEx As Exception ' ' Process program exception ' End Try End Sub
Ultrajones
