Hi all,
Been using PH location successfully for a while now but newbie as far as ibeacons are concerned.
I have purchased one of these and trying to familiarise myself with them.
I sort of understand the major minor principle and its uses. I have added ibeacon to PI but my question is, does the Major/Minor settings set in the ibeacon have to match those set n the PI, or can I set them all to 1. Currently set to Major 17698/ Minor 39104 and same in PI. Do these setting matter for just a home/away use?
The Ibeacon appears to work ok but logs in/out randomly on its own even when ibeacon is a few inches from mobile. Power setting is set to max (30 meter range)
I am using beacon with iphone 6 plus. I notice that if I pick up the phone to do something with it it logs back in/out. Is the Bluetooth going to sleep on the phone, hence drops in and out ???
Or....am I missing something in settings or setup procedure?
Help appreciated.
Help appreciated.
