I am getting the following error in the log. I think I updated to .140 on the 22nd, but need to verify.
Jan-22 17:50:03 BLRussound Error SetZonePowerNoQueue(): Command: 4 is not valid.
I don't remember what I did that caused the issue but I have noticed with .140 I am back to having zones not return to previous source or shut off when BLSpeech finishes and I use a zone and not just a single speaker.
Example. I have 3 rooms setup in a zone called SecondFloor. If something goes to BLSpeech with the source of 3 (speech proxy) for the second floor, all 3 rooms turn on, move to source 3, play the speech and then only 2 of them move back to previous source (in this case my ST2 and XM) and then turn off. The third room stays on source 3 and stays on.
We had something like this before and found the plugin was sending to the CAM6.6 messages too fast and the CAM6.6 did not process all of them. Maybe this is happening again?
Not sure what to do to capture this. I can do a debug log if that helps.
Michael
Michael
