I have just installed an Aeotec nano dimmer with my Homeseer Hometroller S2 (AU). I am needing help configuring the setting to make it work with the Alexa skill. It appears there are two devices in homeseer. One is called a Binary Switch and one is Multilevel Switch. The Only one that seems to work with the Alexa skill is the Multilevel, which means I can turn lights on and dim them but I cannot turn them off via voice command. Is there a way I can use both so I can control on off as well as dim?
