Why these timing events won't work
    Why these two timing events won't work. They are pretty simple trigger 1:00AM and conditions are time/date related. Pls note that "any year" is selected at the second screenshot.
    I also tried same with the letter Y in the dates, like this 04/01/Y and still no luck.
    These Conditions should work. It appears that you are using your keyboard to enter the date - that is the only way you can get 4/1/. The letter Y for any year is appended to the displayed date, but it is not how it is stored in the Event “ blob” in the database. The Condition will not work if you manually enter the date, you must use the pop up selector to populate the date(s). Try rebuilding the Events and use the date selector pop up and they should work.
      Yes indeed it works now. Thank you so much for the enlightenment.
