Help page
    Help page
    Dear Blade,
    I have found the following in the description of the BL Security plugin: "Scripting calls are accessible in the plug-in. See the help page in the plug-in for details." If I click the "Help" button, after a while I get an error message: Timeout from host.
    Can I download this help file from anywhere?
    Thank you in advance,
    Istvan
    The help link in the list of menu links for the plugin
    It should open another window
    Cheers,
    Bob
      Yes, I did it. The new window opens but it seems to load but nothing else happens.
        http://192.168.0.105/BLHelp/BLSecuri...urity_Help.asp doesn't work.
        Raspberry PI2
        Current version is: HS3 ZEE S2 Edition 3.0.0.208
        BLSecurity Plug-in V2.0.32.0
          That is odd and must have to do with something on the PI. I have no idea what on the PI would cause that. Maybe one of the PI SMEs could help
          I just ran that page on Windows and it worked fine
          Cheers,
          Bob
            Blade,
            .ASP pages are not supported on any Linux version of HS3 as it is VBScript based. .ASPX may not work either on some PI models as it takes too long to render and will time out.
            Jon
              I did not know. Thanks Jon
              I have hosted the BLSecurity Help pages here:
              http://bladeplugins.no-ip.org/BLHelp...urity_Help.asp
              Cheers,
              Bob
                Thak you for your help. I installed HS3 on Windows and the Help menu works perfectly there.
