Moving to another PC (and maybe moving back)
    Hi all,
    As some may have seen in my other thread, I'm having random delays in devices turning on whether it's via motion or directly via the HS page.
    My setup currently is 1x HP DL380 server running Windows 2012 R2 + Hyper-V and within that, I'm running a Windows 7 VM with 4GB issued to it.
    My hunch is that I am using USB Redirector between the server and HS3 VM so that the Aeotec z-stick can be read within the VM.
    It's entirely possible it's that setup especially the software com port replicator is the issue.
    I've found a post from LeoS (https://forums.homeseer.com/showpost...20&postcount=4) explaining how to shift to another machine.
    If I did this and put it on a dedicated W7 laptop...And then found the issue remained, could I simply shut down the laptop, put the USB z-stick back into the server, launch the VM and simply carry on as per usual or would the stick still think it's linked to the laptop?
