I just purchased a Lutron Caseta pro hub and am trying this plugin. I can't get it to connect by SSH it keeps logging...
Unable connect to the SmartBridgeS4 SSH check the IP address. Error: 192.168.1.57:22....Server response does not contain SSH protocol identification.
or
Unable connect to the SmartBridgeS4 SSH check the IP address. Error: 192.168.1.57:22....Permission denied (publickey).
It appears I can add the devices manual which I did successfully with a pico remote. Is there a way to find the Id address of each device or do I just assume they are in sequential order? Is this the best this plugin will be able to do or is there hope you will figure out the SSH connection or is there something I need to do to make it work?
or
