Disregard, I've sorted it out mostly.
However, in sorting it out, I was getting a lot of errors when a FolowMee device was active (running on iOS):
So basically I scrapped that and will be testing Locativ and iCloud.
Apr-20 12:54:56 PM PHLocation (PollFM) Error getting FM position data for device [321]
Apr-20 12:54:56 PM PHLocation Error (GetFMData) General exception! System.Xml.XmlException: Data at the root level is invalid. Line 1, position 1. at System.Xml.XmlTextReaderImpl.Throw (System.Exception e) [0x00027] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlTextReaderImpl.Throw (System.String res, System.String arg) [0x00029] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlTextReaderImpl.Throw (System.String res) [0x00000] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace () [0x0012c] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlTextReaderImpl.ParseDocumentContent () [0x002d4] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlTextReaderImpl.Read () [0x0008c] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlLoader.Load (System.Xml.XmlDocument doc, System.Xml.XmlReader reader, System.Boolean preserveWhitespace) [0x000a6] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlDocument.Load (System.Xml.XmlReader reader) [0x0002e] in <0804803de48843fa9b27096f25e9a242>:0 at System.Xml.XmlDocument.Load (System.String filename) [0x00013] in <0804803de48843fa9b27096f25e9a242>:0 at p.a (System.String A_0, System.String A_1, System.String A_2) [0x0005a] in :0
