I purchased this valve from the HS Store, and while it added successfully to my Z-NET, I'm having an issue with the "Valve Fault" feature:
With any number of valves connected, I get a "Valve Fault" error (blinking red Status LED, Active LED off). With no valves connected, I still get a "Valve Fault" error (blinking red Status LED), but the Active LED is Red. The valves and wiring work properly with 3 other controllers. I'm wondering if the Valve Fault Detection is faulty in this unit, if the Valve Fault Detection can be turned off, or should I just return the controller?
I contacted HS Support on 3/10/2017, but I'm still waiting to hear back from them.
