I added this to a different thread but afterwords I thought it deserved its own thread.
I have a th8320zw thermostat and its working just fine. I can operate it from the app just fine. But I want to change the temp for an interval and then have it resume the internal programming, just like as if i pressed the cancel button in the lower right corner on the screen. My event looks like this:
It appears that the "resume last" isn't the same as hitting the cancel button on the touch screen. That appears to shift to the prior mode, not follow program.
Any advice? What I really want to do is to engage the "follow programming" mode that comes up when you hit the cancel button.
- if manually triggered
- set thermo cooling temp to 75*F
- set thermo mode to "resume last" after waiting 4 hours
