I just installed the plugin and added 8 IR codes to the IR Blaster. I can send the IR codes through the IR Blaster from the UltraGCIR "IR Control" web page.
Nothing happens when I try to select them from the control on the device page. The device value of the IR Blaster is stuck on 0 which = "off".
Also, nothing happens when I set an event to control the IR Blaster device.
I tried turning on debug logging but nothing showed up in the homeseer log.
