Using the WWW Page to configure the Elk Plug-In, the "remotearm" parameter keeps re-setting to True whenever I access and set the configuration. I did not see a check box for this setting, did I miss it?
I do not want to allow remote arming of my system, therefore I want this setting to be False. I manually set it in the config file, but again I have to be careful to check this setting if I turn on debug or something which requires access to the WWW config page.
-Mike
-Mike
