Team,
"StatusColors" in HST are supposed to be based on the device status.
In real life it is based on the device status TEXT, not on the actual Status (on=2,off=3,etc)
HST:1.0.0.58, Designer: 1.0.72
Help text:
I have tested this in multiple ways with the same result. Many of my devices have different device-strings but use the device status.
To me this is a pretty major bug. What are your ideas?
DJ
Help text:
If an element has a status text association set (using StatusTracking...) then this property will be available. Use this to assign a different background color, font color, or alternate text to an element. For example, you can assign a different background color to the element if a HomeSeer device is ON or OFF or DIM, or change the displayed text to "Light On" when the devices's status is set to ON.
DJ
