Ocelot Plug-In for HS3
Description:
Plug in for Applied Digital Ocelot/Leopard.
This plug-in provides an RS232 interface from the Ocelot to Homeseer 3.0.0.208 or higher.
Features:
Limitations:
Online Help
The latest CMAX is here.
The latest IRMAX is here.
Ocelots and ADICON units can be purchased at Automation Tec
Screen Shots
Description:
Features:
- Individual creation and deletion of IO, Variable, IR(Ocelot/Leopard and Secu16IR), Timers, Bobcats, and X10 devices.
- Variables can be set from the Device Management page, event actions, and scripting.
- Timers can be started and stopped from the Device Management page, event actions, stopped via scripting, and started from any point via scripting.
- IR locations can be sent from the Device Management page, HomeSeer events, and can be learned from the device's Device Config page.
- X10 received signals have event triggers for All ON, All OFF, Unit ON, and Unit OFF commands.
- IO, Timers, Bobcats and Variables can trigger HomeSeer events with device value triggers.
- Event triggers For IR Match
- Scripting for set IO, set variable, set/stop timers, send IR, and send X10.
- X10 can be set/sent from scripting without devices created.
- Works with Windows and Linux.
Limitations:
- Supports any combination of up to (18 max) Secu16, Secu16i, Secu16IR, Bobcat, and Rly08-XA units.
- X10 support for lamp modules, extended lamp modules, appliance modules, and motion sensors at this time.
- Plugin recognizes Ocelot/Leopard slaves but does not read/set variables or send IR at this time
Online Help
Screen Shots
