UltraCID HSPI For HomeSeer [NEW]
    I just added an UltraCID OnRing HomeSeer trigger. It supports "Any" or Ring 1-5.
    Ultrajones
      Thanks! I'll have to give this a try once I get my hands on a USB modem!
      John
      Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
      Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
      HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
      Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
        For those of you having a HomeSeer license issue. Rich said I had a corrupt license file. Please un-install the current version, then install the version I just uploaded to the top of this thread. Please let me know if the license issue is resolved.
        Ultrajones
          unlicensed
          Still won't give me a config button on the setup/interface page.
          I tried several times including using the uninstall feature in your msi file dated 12/11/2008.
          The setup page says 15 days remaining but still no config button just the enable/disable option.
          From the startup log :
          12/11/2008 7:32:52 PM Info Found plug-in: UltraCID, version: 1.1.3267.32684
          12/11/2008 7:33:58 PM Error (1) Unable to initialize interface UltraCID :Either no license or trial has expired
          Neil
          Newmarket Ontario
            Still not working
            I am receiving the same error as Nsisman.
            12/11/2008 9:11:10 PM - Info - Found plug-in: UltraCID, version: 1.1.3267.32684
            12/11/2008 9:11:31 PM - Error - (1) Unable to initialize interface UltraCID :Either no license or trial has expired.
            How do you purchase UltraCID? When I click on purchase I don't see a spot to purchase UltraCID.
              #21
              I am sorry you're experiencing a licensing issue. I just tested the UltraCID plug-in install on a Windows XP SP3 machine that experienced the problem before and it is now loading the plug-in successfully. Please un-install and verify the UltraCID.lf file no longer exists in the HomeSeer2/config directory. Then re-install and try one last time. If that fails, shutdown HomeSeer and drop the attached UltraCID.lf in c:\program files\HomeSeer 2\config.
              Ultrajones
                #22
                Ultra,
                Just tried it twice and verified the lf file is dated 12/12/2008.
                Still exactly the same as was before trying the new lf file.
                Neil
                Newmarket Ontario
                  #23
                  Still not working for me either. I am getting the same error message.
                    #24
                    I am using the mechanism HomeSeer created to license my plug-in, but it's not working. I am at a loss here. I sent another email to Rich. I am waiting for a response.
                    Ultrajones
                      #25
                      Hello,
                      i have tried it again still no luck
                      Also no config button because license file is expired
                      iam waiting for the next trial
                      thanks
                      ed
                        #26
                        Rich has asked someone having a license issue with UltraCID HSPI to open a helpdesk ticket.
                        Ultrajones
                          #27
                          i have opened a helpdesk ticket.
                          i have fix from homeseer now al is working fine
                          ed
                            #28
                            works now
                            I too opened a helpdesk ticket and was sent a fix yesterday by Rich.
                            Now it starts up with a trial licence so should be ok.
                            Neil
                            Newmarket Ontario
                              #29
                              Hello
                              I've tried your plugin : it's very easy to configure modem and events.
                              I don't have license problem for the moment
                              I've tried different CID plugins but yours seems to be the most easier.
                              I would really buy it but I have a big problem with logs :
                              I can't see any call in log files. Modem is connected, database has been created and is opened, plugin status is ok, events are correctly triggered on incoming call, but absolutely nothing in caller log and nothing in caller details, and nothing in homeseerdb.mdb
                              When I activate the debug mode, I can see all information in Homeseer log (RX, date, time and phone number).
                              Thanks for your help.
                                #30
                                Problem, Yet not a problem!
                                Ultra,
                                I installed this plugin. I bought the Rosewill RNX-56USB Conexant Hardware Based 56Kbps USB (Plug & Play) V.92 PCI Date/Fax/TAM modem that you stated would work. I installed the modem and the plugin. I get warning errors at startup, yet the plugin does work. I just hate seeing errors. Any ideas? Could the plugin just not like the COM12?
                                12/17/2008 8:07:24 PM - UltraCID Info - UltraCID - initializing I/O ...
                                12/17/2008 8:07:27 PM - UltraCID Warnin - No response/improper response from modem command 'ATZ'
                                12/17/2008 8:07:29 PM - UltraCID Warnin - No response/improper response from modem command 'ATZ'
                                12/17/2008 8:07:30 PM - Info - Event Trigger "LCD 01"
                                12/17/2008 8:07:30 PM - Info - Running script in background: lcdsetup
                                12/17/2008 8:07:31 PM - UltraCID Warnin - No response/improper response from modem command 'ATZ'
                                12/17/2008 8:07:33 PM - UltraCID Warnin - No response/improper response from modem command 'AT+VCID=1'
                                12/17/2008 8:07:35 PM - UltraCID Error - Failed to initialize caller ID. The command at+vcid=1 failed.
                                12/17/2008 8:07:35 PM - UltraCID Info - Database connection closed successfuly.
                                12/17/2008 8:07:35 PM - UltraCID Info - Database initialization complete. Ready to accept HomeSeer events into database.
                                12/17/2008 8:07:35 PM - Error - Initializing interface: UltraCID->Could not initialize modem caller ID!
                                12/17/2008 8:07:35 PM - Info - Finished initializing plug-in UltraCID
                                12/17/2008 8:07:35 PM - UltraCID Warnin - No response/improper response from modem command 'AT+VCID=1'
                                12/17/2008 8:07:37 PM - UltraCID Warnin - No response/improper response from modem command 'AT+VCID=1'
                                12/17/2008 8:07:52 PM - UltraCID Info - New incoming call detected ...
                                12/17/2008 8:07:53 PM - UltraCID Info - Incoming call from Server Room 1111
                                12/17/2008 8:07:58 PM - UltraCID Info - Ring of existing call detected ...
                                12/17/2008 8:08:23 PM - UltraCID Info - New incoming call detected ...
                                12/17/2008 8:08:24 PM - UltraCID Info - Incoming call from KOVACIK,C 219662xxxx
                                12/17/2008 8:08:29 PM - UltraCID Info - Ring of existing call detected ...
