The only issue I really have is it shows really old programs that don't exist. Like I did a fresh install of the plugin and my ISY has nothing in it, no programs, variables, etc, however the plugin shows 4 programs on there that aren't on the ISY, like "Turn off master bathroom light after 20 minutes" a program that I haven't had on the ISY in months. Not a huge deal but weird that it pulls those when they aren't in the ISY.
ISY Insteon 3.0.0.54 - Beta 54 for HS3
Originally posted by ryuvann View PostI'm sorry I thought I had replied to this! I did get it working and it did work great. Where I'm torn is if I want to pay for Mark's plugin for native support or stick with the ISY. Mark's plugin does work well but I've had a few wonky issues and am nervous because it's not HomeSeer that made it, where as the ISY is made for Insteon out of the box. On the flip side if you stop your plugin then I'm stuck with an expensive ISY for nothing! But I guess better than if Mark stops his as at least I can use the ISY.
I noticed that my Z-Wave lights all added to HomeSeer as well which was nice. Not sure about locks or other things as I have a Z-Wave USB stick on HS3 already so no real need.
Going to give it a try once more as I have a few days left on the trial for Mark's plugin. I'm just so nervous January might roll around and you might disappear and then the plugin expires and I'm stuck!
Originally posted by ryuvann View PostThe only issue I really have is it shows really old programs that don't exist. Like I did a fresh install of the plugin and my ISY has nothing in it, no programs, variables, etc, however the plugin shows 4 programs on there that aren't on the ISY, like "Turn off master bathroom light after 20 minutes" a program that I haven't had on the ISY in months. Not a huge deal but weird that it pulls those when they aren't in the ISY.
The data about the devices created resides in the HomeSeer database, not in a plug-in specific data store. So just removing the plug-in doesn't clear out the device records stored in the HomeSeer database. I'm guessing that the 4 programs just never got deleted from HomeSeer.
It's usually easy enough to delete the HomeSeer records manually and if something is removed that shouldn't be, the plug-in will re-created it on the next restart. The only real issue is if you delete a device that has events associated with it, the events may be left in limbo.
It also may be possible that the ISY is sending info about those programs but that they're marked as deleted and the plug-in is ignoring that. If that's the case, and they re-appear in HomeSeer after deleting them, let me know.
I think it's the later as I deleted all traces of the plugin when I used it before (also pretty sure it showed old programs even then), and then I deleted everything from the ISY, all devices, scenes, programs etc. There's no devices in HS3 for the ISY either only Z-Wave ones. Not sure why it shows them, I just clicked Hide (which didn't actually delete their devices or hide them at all) so then manually deleted them from the HS3 device listing so seems okay. Very odd though!
Side question, if I want to use a HS3 event to illuminate a KeyPadLinc button, do I still need to do like on the ISY and create scenes with those buttons as responders, or does your plugin have any capability to turn on or off a button without using a scene?
Originally posted by ryuvann View PostI think it's the later as I deleted all traces of the plugin when I used it before (also pretty sure it showed old programs even then), and then I deleted everything from the ISY, all devices, scenes, programs etc. There's no devices in HS3 for the ISY either only Z-Wave ones. Not sure why it shows them, I just clicked Hide (which didn't actually delete their devices or hide them at all) so then manually deleted them from the HS3 device listing so seems okay. Very odd though!
Another quick question, is there anything special needed to use the Hidden Door Sensor? I added it to the ISY and it works fine there but in HS3 it shows it as a device but when the door is open, it shows no status, there's no status icon or anything, and when the door is closed it shows the Off icon. Not sure if it's a huge deal or not but doesn't seem to show Open. I see under status it shows 0 for closed and 255 for open but tried deleting re-adding etc no luck. It seems the Off works but not On. I have it set just as 1 device not the 2.
Did a test event just to check, told it to turn a light on if On and turn it off if Off. When I close the door the light goes off, but opening it does noting even though the ISY shows ON.
Originally posted by ryuvann View PostAnother quick question, is there anything special needed to use the Hidden Door Sensor? I added it to the ISY and it works fine there but in HS3 it shows it as a device but when the door is open, it shows no status, there's no status icon or anything, and when the door is closed it shows the Off icon. Not sure if it's a huge deal or not but doesn't seem to show Open. I see under status it shows 0 for closed and 255 for open but tried deleting re-adding etc no luck. It seems the Off works but not On. I have it set just as 1 device not the 2.
Was a false alarm actually! I had it set so 0 is Closed and 255 is Open, but it would only ever show Closed. If it was open there would be no status or icon. I then added a new Z-Wave switch that is to be controlled by the hidden door sensor so I had to restart HS3, as I always have to after adding a new Z-Wave for some reason. Restarting it fixed the problem and the hidden door sensor works perfect, shows open and closed as expected.
Hi there, just noticed a bug I thought I'd share.
If I have an event like:
If An ISY Device Event Happens Kitchen Light Sends Fast On, Then Set Device Dining Room Light to On
And I do the copy Event, and then change the copied one to "Sends Fast Off" and "Then Set Device Dining Room Light to Off", when I save it changes the "Sends Fast Off" back to Sends Fast On. If I change the first Event to Fast Off, it changes this one to Fast Off as well.
Only way to make it work was to make 2 separate events and not copy them. Only have this problem with the ISY plugin, everything else copies events just fine.
That does sound like a bug. I'll take a look at it.
Thanks for the report.
Originally posted by ryuvann View PostHi there, just noticed a bug I thought I'd share.
For some reason,HS3 is no longer working with my ISY994i IR. I had been on version 3.0.0.27 when this happened. I decided the trial had expired, and installed 3.0.0.31, but same thing. ISY Firmware: 5.0.6 (Alpha) ... not sure if the loss of HS control correlates to updating the ISY or not.
I've tried restarting HS3 and the ISY. The plug-in's "Device Filters" page only shows ISY Programs, and ISY Variables. No devices. The
Here are a few snips from the HS3 Log:
Oct-16 4:43:01 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:43:01 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:43:01 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:43:00 PM ISYInsteon SetLocation2 : Setting Location 2 failed for /ISY Programs. option = 2
Oct-16 4:43:00 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:43:00 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:43:00 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:59 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:59 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:59 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:58 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:58 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:58 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:57 PM ISYInsteon Found 6 state variables
Oct-16 4:42:57 PM ISYInsteon Found 3 integer variables
Oct-16 4:42:57 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:57 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:57 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:56 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:56 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:56 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:55 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:55 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:55 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:54 PM ISYInsteon + 21090 Elk Security System
Oct-16 4:42:54 PM ISYInsteon + 21040 Networking Module
Oct-16 4:42:54 PM ISYInsteon + 21010 OpenADR
Oct-16 4:42:54 PM ISYInsteon Modules installed on ISY:
Oct-16 4:42:54 PM ISYInsteon InitialGetNodes : ISY node configuration query returned no devices or scenes.
Oct-16 4:42:54 PM ISYInsteon InitialGetNodes : ISY node configuration query returned an empty scene list.
Oct-16 4:42:54 PM ISYInsteon InitialGetNodes : ISY node configuration query returned an empty device list.
Oct-16 4:42:54 PM ISYInsteon SendRequest : The 's:Envelope' start tag on line 1 position 25 does not match the end tag of 's:Envelop'. Line 1, position 80375.
Oct-16 4:42:54 PM ISYInsteon SendRequest : Poorly defined XML - Hidden Lake Estate
27721
Gabbys22600
57084
Front Room28308
4819
Den22600
2625
Keypads59136
12819
Master Bath22600
21182
Master Bedroom22600
32508
Entry28308
413
Maintenance
36335
Plant Room22600
57036
Holiday Lighting28751
8011
Status LEDs59136
51222
Unused59136
64969
3-Way Switches59136
29555
Lighting Groups28751
59776
Controllers59136
31365
Batteries413
28751
Scenes
38991
Living Room28308
52115
Dining Room28308
22600
Upstairs
48274
Garage28308
28308
Downstairs
Oct-16 4:42:54 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:54 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:54 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:54 PM ISYInsteon ISY Firmware version: 5.0.6
Oct-16 4:42:53 PM Plug-In Finished initializing plug-in ISYInsteon
Oct-16 4:42:53 PM ISYInsteon Skipping [/zwaveServices]
Oct-16 4:42:53 PM ISYInsteon Skipping [/zwaveServices.wsdl]
Oct-16 4:42:53 PM ISYInsteon Checking service type: UDIZWaveWebServices
Oct-16 4:42:53 PM ISYInsteon Skipping [/sepServices]
Oct-16 4:42:53 PM ISYInsteon Skipping [/sepServices.wsdl]
Oct-16 4:42:53 PM ISYInsteon Checking service type: UDISEPWebServices
Oct-16 4:42:53 PM ISYInsteon Skipping [/security/elk]
Oct-16 4:42:53 PM ISYInsteon Skipping [/elkServices.wsdl]
Oct-16 4:42:53 PM ISYInsteon Checking service type: UDIELKWebServices
Oct-16 4:42:53 PM ISYInsteon Checking service type: urn:udi-com:service:X_Insteon_Lighting_Service:1
Oct-16 4:42:53 PM ISYInsteon Creating isy class instance: [192.168.1.4]
Oct-16 4:42:53 PM ISYInsteon GetOptions : Leave
Oct-16 4:42:53 PM ISYInsteon GetOptions : Enter
Oct-16 4:42:53 PM ISYInsteon InitIO : Enter - Called with COM1
Oct-16 4:42:53 PM Info Plugin ISYInsteon has connected. IP:127.0.0.1:64900
Oct-16 4:42:53 PM ISYInsteon I have connected to HS
Oct-16 4:42:53 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:53 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:52 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:52 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:51 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:51 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:50 PM Error Calling SetIOMulti in plugin ISYInsteon:Object reference not set to an instance of an object.
Oct-16 4:42:50 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:50 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:49 PM Error Calling SetIOMulti in plugin ISYInsteon:Object reference not set to an instance of an object.
Oct-16 4:42:49 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:49 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:48 PM Error Calling SetIOMulti in plugin ISYInsteon:Object reference not set to an instance of an object.
Oct-16 4:42:48 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:48 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:47 PM Info Plugin ISYInsteon with instance: has disconnected
Oct-16 4:42:47 PM Error Calling SetIOMulti in plugin ISYInsteon:Object reference not set to an instance of an object.
Oct-16 4:42:47 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:47 PM ISYInsteon Clear all event handlers.
Oct-16 4:42:47 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:47 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:46 PM ISYInsteon Return from subscription thread
Oct-16 4:42:46 PM ISYInsteon Attemp to close TcpClient
Oct-16 4:42:46 PM ISYInsteon Read exited with True
Oct-16 4:42:46 PM ISYInsteon start thread shutdown functions.
Oct-16 4:42:46 PM ISYInsteon Stop called.
Oct-16 4:42:46 PM Plug-In Shutting down Plug-In: ISYInsteon
Oct-16 4:42:46 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:46 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:42:46 PM Event Event Trigger "System LED Battery Charger OFF"
Oct-16 4:42:45 PM ISYInsteon SetIOMulti : ISY device mapping failure: No matching record for ID 101
Oct-16 4:42:45 PM Device Control Device: Downstairs Kitchen Charger 6-LED Candles to Off (0)
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 3F 4D 38 2
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 3F 4D 38 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 37 5B 5D 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 23 41 2F 2
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 23 41 2F 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 18 96 BC 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 25 B8 68 4
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 25 B8 68 2
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 25 B8 68 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1B BE 11 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1C 9D F 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 25 CB 83 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 33 33 33 6
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 33 33 33 5
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 33 33 33 4
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 11 BD 72 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 10 3 50 6
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 10 3 50 5
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 17 6F B7 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 10 3 50 4
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 10 3 50 3
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device C 4 D3 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B C
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 10 3 50 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 33 33 33 3
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B B
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B A
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B 9
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B 2
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 1E 7E 7B 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 11 B7 7F 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 11 BB 7E 1
Oct-16 4:39:18 PM ISYInsteon UpdateEvent : UpdateEvent unknown device 17 D5 F6 2
Originally posted by CJVann View PostFor some reason,HS3 is no longer working with my ISY994i IR. I had been on version 3.0.0.27 when this happened. I decided the trial had expired, and installed 3.0.0.31, but same thing. ISY Firmware: 5.0.6 (Alpha) ... not sure if the loss of HS control correlates to updating the ISY or not.
The failure is happening as the plug-in tries to get the list of devices from the ISY. the XML sent by the ISY looks like it was truncated, based on the info in the log. But I can't tell if that's because something is bad in the XML (all the XML formatting got stripped either in the log output or in your cut-n-paste) or because something ran out memory or because the ISY truncated the response. If the plug-in ran out of memory trying to read it, an out of memory exception should have happened.
Given that this is what was reported:
I don't have 5.0.6 yet and haven't tried it.
So, I didn't realize there was a new version and the ISY plugin stopped working today (I was on .25).
While in beta, could you add:
1) a version check to see if a newer version is available, which emails and lets you know when a new version is detected (a simple call to a TXT file on your server could tell the plugin which version is current)
2) the ability to have the plugin email you when the plugin is about to expire.
Not sure how much work those are, but it would help out.
