Help me out Spud
    Help me out Spud
    I'm trying to set a timer with the difference between 2 other timers using ($$DVR:941: - $$DVR:928 I keep getting an error, and I have tried till I want to pull my hair out... what do I do?
    EasyTrigger ERROR SetDeviceValue: Cannot find control value 300 for device 942
    The HomeSeer timer and counter devices are for display only, they cannot be controlled. As a result you cannot control a counter or timer from the Easy Trigger plug-in. The only way to control a timer from within an event is with the "control a timer" action.
      I started out trying to set a virtual switch with the difference between the two. and I was having trouble with that too. Is that possible?
        yes it's possible, but in your virtual device you need to define a range of values that are controls (or both status and control)
          I got it! thanks to both of you!
