Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old September 22nd, 2014, 08:04 AM
eole's Avatar
eole eole is offline
Device string and value not updated [SOLVED]
Hi Philippe,
I've bought your plugin for my HS3 server (in test for the moment).
I've connected an APC Back-UPS CS650 with usb cable and an APC Smart-UPS 2200 remotely
In status page, I can see almost all fields, excepted Nominal Power, Input Voltage, Low & High Line Voltage, Low & High Load, Low & High Battery Charge
But in device manager, only the following are filed :
Name
Start Time
Last Updated
Status flag
Status
Time Left
Last on Battery
Lost off Battery
Total Time on Battery
Number of Transfers
Do you have any idea ?
Thanks in advance.
Yves
HS 3.0.0.318 Pro virtualized
Plugins & Scripts : APCUPSD, BLBackup, BLLan, Device History, HSTouch, IPX800, IRTrans, NetCam, PHLocation, ProgTV, Reveils, RFXCOM, SNCF, UltraCID3, Z-Wave, 1-Wire, WhoIs, EasyTrigger, RaspberryIO
HW : HPN54L with Esxi 5.5,
RFXCom LAN, IRTrans LAN+USB, USBModem, Oregon Scientific Sensors, 1-Wire, IPX800, Z-Wave devices
Old September 23rd, 2014, 07:00 AM
pcp pcp is online now
Super Seer
If you don't see the values in the plugin status page most likely the UPS is not sending these via APCUPSD or the plugin could not decode them. Try the following:
a) in the apcupsd status (from the icon in the toolbar) do you these values?
b) enable debut + verbose debug in the plugin. The log file should contain what the plugin receives and can decode. If you post the log I can have have a look at it as well.
Bonne journee.
Old September 23rd, 2014, 07:29 AM
eole's Avatar
Hi Philippe,
In the apcupsd status, I can see all informations. On local and on remote PC.
Here is the verbose log (the UPS1 is the remote one, UPS2 is the local) :
sept.-23 13:38:02 APCUPSD Debug --------------- refreshTimer END -----------------
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 237, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 236, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 235, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 234, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 233, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 232, Value: 1
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 231, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 230, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 229, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 221, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 222, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 228, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 227, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 226, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 225, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 224, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 223, Value: 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 218, Value: 1411479481
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 217, Value: 1411433570
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 219, Value: 1
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 220, Value: 1
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 216, Value: 2
sept.-23 13:38:02 APCUPSD (UPS2) Debug Update devices for UPS2
sept.-23 13:38:02 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status and events for UPS2 done
sept.-23 13:38:02 APCUPSD (UPS2) Debug QueryStatusAndEvents - Got status
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered tcpClient_onDisconnect() UPS2
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): END APC : 2014-09-23 13:38:01 +0100
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (29): FIRMWARE : 817.v4.I USB FW:v4
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMPOWER : 400 Watts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): NOMBATTV : 12.0 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMINV : 230 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMOUTV : 230 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTDATE : 2012-05-02
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): SERIALNO : 3B0622X58167
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): MANDATE : 2006-05-28
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): STATFLAG : 0x05000008
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (15): STESTI : None
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (13): SELFTEST : NO
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (14): XOFFBATT : N/A
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CUMONBATT: 0 Seconds
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): TONBATT : 0 Seconds
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (12): NUMXFERS : 0
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (27): LASTXFER : Low line voltage
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (18): LINEFREQ : 50.0 Hz
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTV : 13.6 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): ALARMDEL : No alarm
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): ITEMP : 29.2 C
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): RETPCT : 0.0 Percent
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): HITRANS : 256.0 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LOTRANS : 180.0 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DSHUTD : 0 Seconds
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DWAKE : 0 Seconds
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): SENSE : Medium
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): OUTPUTV : 230.0 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MAXTIME : 0 Seconds
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MINTIMEL : 3 Minutes
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MBATTCHG : 5 Percent
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): TIMELEFT : 32.5 Minutes
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (24): BCHARGE : 100.0 Percent
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): LOADPCT : 10.0 Percent
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LINEV : 246.0 Volts
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): STATUS : ONLINE
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (26): MODEL : Back-UPS CS 650
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): STARTTIME: 2014-09-23 00:52:50 +0100
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): UPSMODE : Stand Alone
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (25): DRIVER : USB UPS Driver
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CABLE : USB Cable
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): UPSNAME : BATIMENT
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (16): HOSTNAME : DOMO2
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): DATE : 2014-09-23 13:38:01 +0100
sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): APC : 001,045,1037
sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - reading status
sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status for UPS2 from network
sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - Connected and query status
sept.-23 13:38:01 APCUPSD (UPS2) Debug Entering QueryStatusAndEvents for UPS2
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 166, Value: 86
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 165, Value: 163
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 164, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 163, Value: 1411434058
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 162, Value: 1411434057
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 161, Value: 1
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 160, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 159, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 158, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 150, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 151, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 157, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 156, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 155, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 154, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 153, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 152, Value: 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 147, Value: 1411479492
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 146, Value: 1406396492
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 148, Value: 1
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 149, Value: 1
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 145, Value: 2
sept.-23 13:38:01 APCUPSD (UPS1) Debug Update devices for UPS1
sept.-23 13:38:01 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status and events for UPS1 done
sept.-23 13:38:01 APCUPSD (UPS1) Debug QueryStatusAndEvents - Got status
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered tcpClient_onDisconnect() UPS1
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): END APC : 2014-09-23 13:38:16 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): FIRMWARE : 80.14.I
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (12): EXTBATTS : 0
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): NOMBATTV : 48.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): NOMOUTV : 225 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): BATTDATE : 06/28/13
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): SERIALNO : YS0321210433
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): MANDATE : 05/20/03
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG3 : 0x00
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG2 : 0x00
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG1 : 0x00
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): DIPSW : 0x00
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): STATFLAG : 0x05000008
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (14): STESTI : 336
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): SELFTEST : NO
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): LASTSTEST: 2014-09-20 17:39:50 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XOFFBATT : 2014-09-23 01:00:58 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): CUMONBATT: 163 Seconds
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): TONBATT : 0 Seconds
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XONBATT : 2014-09-23 01:00:57 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): NUMXFERS : 86
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (38): LASTXFER : Line voltage notch or spike
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): LINEFREQ : 50.0 Hz
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): BATTV : 55.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): ALARMDEL : Low Battery
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): ITEMP : 32.8 C
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): RETPCT : 0.0 Percent
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): HITRANS : 253.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LOTRANS : 196.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): DLOWBATT : 2 Minutes
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): DSHUTD : 180 Seconds
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): DWAKE : 60 Seconds
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): SENSE : High
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): OUTPUTV : 247.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MINLINEV : 236.6 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MAXLINEV : 249.6 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MAXTIME : 0 Seconds
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MINTIMEL : 3 Minutes
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MBATTCHG : 5 Percent
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): TIMELEFT : 139.0 Minutes
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): BCHARGE : 100.0 Percent
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): LOADPCT : 12.4 Percent
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LINEV : 247.0 Volts
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): STATUS : ONLINE
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (25): MODEL : SMART-UPS 2200
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): STARTTIME: 2014-07-26 17:41:32 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): UPSMODE : Stand Alone
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (30): DRIVER : APC Smart UPS (any)
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (29): CABLE : Custom Cable Smart
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): UPSNAME : APC2200
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): HOSTNAME : domoware
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): DATE : 2014-09-23 13:38:12 +0100
sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): APC : 001,053,1256
sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - reading status
sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - Connected and query status
sept.-23 13:38:00 APCUPSD (UPS1) Debug Entering QueryStatusAndEvents for UPS1
sept.-23 13:38:00 APCUPSD Debug Entered refreshTimer_Elapsed()
sept.-23 13:38:00 APCUPSD Debug --------------- refreshTimer START -----------------
sept.-23 13:37:22 APCUPSD Debug PostBackProc - Form data name: id Value: verbosedebug
sept.-23 13:37:22 APCUPSD Debug Entered postBackProc() apcupsd_config. page: apcupsd_config data: erbosedebug=checked&id=verbosedebug user: YC userRights: 6
sept.-23 13:37:22 APCUPSD Debug Entered PostBackProc(). Page: apcupsd_config data: verbosedebug=checked&id=verbosedebug User: YC userRights: 6
Hope it'll help.
Thanks in advance.
Old September 23rd, 2014, 11:56 PM
Super Seer
Thank you for posting the log; based on this somehow the plugin cannot parse / extract the value. I will have to look at it this weekend, but my guess is that it is related to some locale settings (. versus ,). Vous etes en France avec une configuration utilisant le comma pour les decimales?
Old September 24th, 2014, 03:50 AM
eole's Avatar
You're right, I'm in France and run a Windows 7 Pro French.
I'm using comma by default.
It's probably the same problem on the HS2 server which is Windows XP Pro SP3 French and can't also update the values.
Otherwise this plugin seems really perfect.
Thanks for your help.
Old September 24th, 2014, 07:57 AM
Super Seer
Thanks. I look into it over the weekend. Per the log you posted apcupsd does not use the local and uses a dot instead of a comma and believe that must be the issue.
Old September 28th, 2014, 07:21 PM
Super Seer
I made some changes to see if that will resolve (or work around) the issue. Can you try the attached plugin version as a test?
Just copy it to the HomeSeer installation folder to overwrite the existing. Merci.
I did not have enough time to check if apcupsd can be reconfigured to use your French locale for numbers (and therefore be compatible with the numeric conversion which uses your locale).
Old September 29th, 2014, 03:10 AM
eole's Avatar
Thanks for this, but I doesn't seems to be solved ; I think you'll have to spend more week-ends . Sorry for French locale for numbers...
sept.-29 05:05:56 APCUPSD Debug --------------- refreshTimer END -----------------
sept.-29 05:05:56 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 237, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 236, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 235, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 234, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 233, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 232, Value: 1
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 231, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 230, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 229, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 221, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 222, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 228, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 227, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 226, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 225, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 224, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 223, Value: 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 218, Value: 1411967111
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 217, Value: 1411915084
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 219, Value: 1
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 220, Value: 1
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 216, Value: 2
sept.-29 05:05:55 APCUPSD (UPS2) Debug Update devices for UPS2
sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status and events for UPS2 done
sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Got status
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered tcpClient_onDisconnect() UPS2
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): END APC : 2014-09-29 05:05:55 +0100
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (29): FIRMWARE : 817.v4.I USB FW:v4
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMPOWER : 400 Watts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): NOMBATTV : 12.0 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMINV : 230 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMOUTV : 230 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTDATE : 2012-05-02
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): SERIALNO : 3B0622X58167
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): MANDATE : 2006-05-28
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): STATFLAG : 0x05000008
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (15): STESTI : None
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (13): SELFTEST : NO
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (14): XOFFBATT : N/A
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CUMONBATT: 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): TONBATT : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (12): NUMXFERS : 0
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (27): LASTXFER : Low line voltage
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (18): LINEFREQ : 50.0 Hz
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTV : 13.6 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): ALARMDEL : No alarm
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): ITEMP : 29.2 C
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): RETPCT : 0.0 Percent
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): HITRANS : 256.0 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LOTRANS : 180.0 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DSHUTD : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DWAKE : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): SENSE : Medium
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): OUTPUTV : 230.0 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MAXTIME : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MINTIMEL : 3 Minutes
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MBATTCHG : 5 Percent
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): TIMELEFT : 26.2 Minutes
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (24): BCHARGE : 100.0 Percent
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): LOADPCT : 17.0 Percent
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LINEV : 240.0 Volts
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): STATUS : ONLINE
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (26): MODEL : Back-UPS CS 650
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): STARTTIME: 2014-09-28 14:38:04 +0100
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): UPSMODE : Stand Alone
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (25): DRIVER : USB UPS Driver
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CABLE : USB Cable
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): UPSNAME : BATIMENT
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (16): HOSTNAME : DOMO2
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): DATE : 2014-09-29 05:05:11 +0100
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): APC : 001,045,1037
sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - reading status
sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status for UPS2 from network
sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Connected and query status
sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering QueryStatusAndEvents for UPS2
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 166, Value: 92
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 165, Value: 174
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 164, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 163, Value: 1411866080
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 162, Value: 1411866078
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 161, Value: 1
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 160, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 159, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 158, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 150, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 151, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 157, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 156, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 155, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 154, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 153, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 152, Value: 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 147, Value: 1411967162
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 146, Value: 1406396492
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 148, Value: 1
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 149, Value: 1
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 145, Value: 2
sept.-29 05:05:55 APCUPSD (UPS1) Debug Update devices for UPS1
sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status and events for UPS1 done
sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Got status
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered tcpClient_onDisconnect() UPS1
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): END APC : 2014-09-29 05:06:06 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): FIRMWARE : 80.14.I
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (12): EXTBATTS : 0
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): NOMBATTV : 48.0 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): NOMOUTV : 225 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): BATTDATE : 06/28/13
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): SERIALNO : YS0321210433
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): MANDATE : 05/20/03
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG3 : 0x00
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG2 : 0x00
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG1 : 0x00
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): DIPSW : 0x00
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): STATFLAG : 0x05000008
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (14): STESTI : 336
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): SELFTEST : NO
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): LASTSTEST: 2014-09-20 17:39:50 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XOFFBATT : 2014-09-28 01:01:20 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): CUMONBATT: 174 Seconds
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): TONBATT : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XONBATT : 2014-09-28 01:01:18 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): NUMXFERS : 92
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (38): LASTXFER : Line voltage notch or spike
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): LINEFREQ : 50.0 Hz
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): BATTV : 55.0 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): ALARMDEL : Low Battery
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): ITEMP : 33.7 C
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): RETPCT : 0.0 Percent
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): HITRANS : 253.0 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LOTRANS : 196.0 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): DLOWBATT : 2 Minutes
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): DSHUTD : 180 Seconds
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): DWAKE : 60 Seconds
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): SENSE : High
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): OUTPUTV : 241.8 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MINLINEV : 240.5 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MAXLINEV : 243.1 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MAXTIME : 0 Seconds
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MINTIMEL : 3 Minutes
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MBATTCHG : 5 Percent
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): TIMELEFT : 123.0 Minutes
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): BCHARGE : 100.0 Percent
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): LOADPCT : 14.5 Percent
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LINEV : 241.8 Volts
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): STATUS : ONLINE
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (25): MODEL : SMART-UPS 2200
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): STARTTIME: 2014-07-26 17:41:32 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): UPSMODE : Stand Alone
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (30): DRIVER : APC Smart UPS (any)
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (29): CABLE : Custom Cable Smart
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): UPSNAME : APC2200
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): HOSTNAME : domoware
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): DATE : 2014-09-29 05:06:02 +0100
sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): APC : 001,053,1256
sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - reading status
sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Connected and query status
sept.-29 05:05:54 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
sept.-29 05:05:54 APCUPSD (UPS1) Debug Entering QueryStatusAndEvents for UPS1
sept.-29 05:05:54 APCUPSD Debug Entered refreshTimer_Elapsed()
sept.-29 05:05:54 APCUPSD Debug --------------- refreshTimer START -----------------
Old September 29th, 2014, 05:09 AM
Super Seer
Thanks and yes will have to spend more time looking into this. The issue per the log entries is that apcupsd does not use the locale; at least I think.
Old October 13th, 2014, 05:50 AM
Super Seer
FYI, I have not forgotten about this tough only had very limited time since my last update.
Old October 13th, 2014, 06:59 AM
eole's Avatar
Thanks Philippe, I'll still wait... a few hours
Old October 21st, 2014, 07:08 AM
eole's Avatar
Hi Philippe,
You're right : i've tried switching local settings from FR to US (dot and not coma) and it works fine. All fields are filled. So this is the issue.
I can let it work a moment for testing, but you're next update will be welcome.
Thanks in advance.
Old October 21st, 2014, 07:53 AM
Super Seer
I played with it a bit more over the weekend but not complete yet. The issue is that apcupsd sends the numerical as us local (i.e. Using a dot for the decimal separator) while the local on your PC is a comma as the decimal separator. In the plugin version in the post I forced the conversion for APCSUPSD values to use the us local even if the local on your PC is different; I had hoped this would solve it. The real solution would be if apcupsd uses the local for the decimal separator, I checked a bit over the weekend but did not see such a configuration in apcupsd (maybe missed it!).
Old November 2nd, 2014, 07:55 PM
Super Seer
Attached is an updated version of the plugin for testing. Based on my testing this should work (I switched my US computer to FR, but their might still be slight differences). Let me know if that resolves the issue; if so I post an updated version to the Updater.
Old November 10th, 2014, 05:17 PM
Fischi Fischi is offline
Hi Eole,
is the plugin working OK now ?
I live in Germany and I'm also interested in the APS CS 650.
It would be great if it works.
Fischi
Old November 10th, 2014, 08:08 PM
eole's Avatar
Thumbs up SOLVED
Hi Philippe,
Sorry for the delay but I was a bit busy.
I've tried it for remote UPS (APC SmartUPS 2200 with serial to usb adapter) and local UPS (BackUPS CS650 with usb).
The plugin works now fine
For some reason, the APC2200 doesn't send to APCUPSD the nominal power so the graph is empty but, as it's ok for the CS650, the plugin can't be the source of this issue.
Thanks a lot Philippe for your job, it's very useful.
Can I hope the same correction for the HS2 version of your plugin, because I can't migrate for the moment, due to the lack of plugins in HS3 and the huge job to rewrite the scripts ?
Thanks again.
Fitchi, sure you can use this great plugin.
Old November 10th, 2014, 08:25 PM
Super Seer
Thank you for the update. I know about being busy! I will send a new version to the HS3 updater in a few days. As far as hs2 goes, I will see what I can do but might take me a bit.
Old November 21st, 2014, 08:35 AM
Super Seer
The release version is in the Updater. See http://board.homeseer.com/showpost.p...61&postcount=1 for more details
How to Parse device string and create device values dhellis Script & Plug-In Development 6 October 8th, 2012 02:41 PM
How to clear or reset a device status/device string Rupp How-To's 0 January 3rd, 2011 01:30 PM
Parse device string and update as the value of a virtual device ccat HomeSeer General Discussion Area 5 December 14th, 2010 04:32 PM
Device not getting updated johnnyt MCS Temperature 4 April 3rd, 2006 07:32 PM
