Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion > APCUPSD Plugin (3P)
APCUPSD Plugin (3P) Discussions related to the APCUPSD UPS monitoring plugin.
Old May 15th, 2015, 03:53 PM
donstephens's Avatar
donstephens donstephens is online now
Looking for some advice with editing apcupsd.conf
Trying to get this to work, can't get it to connect to a Smart UPS w/ serial cable on COM1. How and where are you guys tweaking this file?
Don
Old May 15th, 2015, 09:13 PM
pcp pcp is online now
Super Seer
I have multiple UPS devices all connected to apcupsd via USB cables, not COM ports. It worked for me out of the box and did not have to tweak the apcupsd.conf file. So not really any specific tips for COM UPC connections. Did you try google?
Old May 15th, 2015, 10:04 PM
No, I should have. Will give it a go.
Old May 15th, 2015, 10:43 PM
madigan's Avatar
madigan madigan is offline
You can find the docs at
http://www.apcupsd.org/manual/manual.html
I recall a few settings to be changed, but I didn't give it a lot of attention, as I have USB APCs.
Old May 16th, 2015, 01:28 AM
LeoS LeoS is offline
Post your UPS model.
If I'm not mistaken APC has 2 protocols that use serial connector, modbus is the newer and open protocol (preferred one).
HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Old May 16th, 2015, 08:55 AM
APC Smart UPS 700. It's a rack mount...
Old May 16th, 2015, 12:25 PM
Have you tried using:
UPSCABLE smart
UPSTYPE apcsmart
DEVICE COM1
Old May 16th, 2015, 12:58 PM
No and that was it.
I had totally screwed up the file.
Thanks for the suggestion.
Now, on the the plugin itself. Can't get it to connect w/ apcupsd. Set the port to 3551, restarted the plugin but still reporting off line. apcupsd is connecting well. Thought I followed the pdf file directions. Guess I missed something.
Thanks to Jeff Farmer, the plugin is working. Despite me....
Old May 16th, 2015, 01:54 PM
Super Seer
No and that was it.
Do you get any error in the hs3 log? I assume you set the update interval to a value, added the ups ups1 tab and enabled it. Can you enable debug in the plugin and post the log?
Old May 16th, 2015, 02:02 PM
Up and running. Thanks
APCUPSD Plug-in for HS2 Discussion pcp Script & Plug-In Library Discussion 3 December 31st, 2015 09:48 AM
How to connect to APCUPSD on remote computer kesterf APCUPSD Plugin (3P) 2 July 3rd, 2014 10:45 PM
apcupsd monitor discussion BootsC5 Script & Plug-In Library Discussion 42 June 3rd, 2014 04:14 AM
APCUPSD Script beerygaz Jon00's plugins and scripts 3 October 10th, 2010 07:28 AM
apcupsd monitor script BootsC5 Script & Plug-In Library 2 May 11th, 2008 09:53 AM
