API Mode and Floats
    #16
    I checked this on this version and it worked fine. Can you send me a debug log of this so I can see what is going on.
    Greig.
    please see attached the whole debug file
      #17
      Can I as what Decimal mark you have set on your system?
      Greig.
      Scripts =
      Various
        #18
        Greig.
        Good point, in Windows it uses the local settings, so I have the comma "," and not the point "."
        for example a Zwave device reports:
        233,715 Volts
          #19
          I guess this is the problem. Can you test it by changing it to see if it helps. I will look at how to fix this.
          Greig.
          Scripts =
          Various
            #20
            Please try V1.0.0.138 from the updater and tell me if this helps.
            Greig.
            Scripts =
            Various
              #21
              Greig.
              Ok, with the latest sketch the device view shows the temperature like this:
              With String:
              14.25C
              With Value& String:
              14.25C
              With Value:
              1425
              Is this the correct behaviour?
              It also seems it is ignoring the localization ("," instead of ".")?
              Will this create issues if I use this in events? for example comparing two values from different devices, one reporting with "," and one with "."?
                #22
                With String:
                14.25C
                With Value& String:
                14.25C
                With Value:
                1425
                Well it looks like my fix did not work. I will have to look at this again. It should have replaced the "." with "," in your location.
                Greig.
                Scripts =
                Various
                  #23
                  OK I have a different fix in place for this in v.139 in the beta updater. You only need to update the plugin and not the board sketch.
                  Greig.
                  Scripts =
                  Various
                    #24
                    Yes I confirm it works now!
                    thanks a lot for fixing it!!
