HomeSeer Amazon Echo Skill Approved!
Just the skill.
Originally posted by gfs View PostSo with the HS skill do I need one of the plug ins? Or can I interface with my HS3 system and my echo just using the skill?
The command is dictated by Amazon, all skills have to start with "tell SKILL to". I wish there was a better way also, I hate having to say that. Note you can also say "Ask HomeSeer to".
There is a HA control SDK where you can just say "tun on the lights", but its very limited with what you can say. We are in direct talks with Amazon and are voicing our concerns, they seem receptive so far, so hopefully we will get some changes.
Originally posted by Dr_Crash View PostAny way to shorten "Tell HomeSeer to"???? This doesn't have a high WAF.
Tell HS kitchen lights off???
Something simple without a mouthful.
Chris
The only way to get a nice short command right now is to use the HA Bridge software which emulates Phillips Hue devices to integrate directly with Amazon's Connected Home features. With that you can say just "Alexa, Turn on..." without the "tell skill name to" part. You can use both the skill and the bridge at the same time so you can turn on and off lights with short commands, and work other devices and events using the skill.
See my thread here for a link to the latest HA Bridge that I'm using, and my script page that can automatically configure your devices in the HA bridge software (otherwise you need to manually enter device names and on and off URLs for each one to get the bridge configured). The script also contains an Alexa Skill, but it's separate from the HA Bridge configurator, so you don't need to use that if you already have the official HS skill up and working.
One note on my script, for some reason the HS Global Cache plugin breaks my script. I hope to work around that issue soon, but until I figure it out GC users can only run the configuraiton script if they remove the plug in completely first. Fortunately the parts that conflict with the GC plugin are things you only need to run once for setup.
Originally posted by rjh View PostThe command is dictated by Amazon, all skills have to start with "tell SKILL to". I wish there was a better way also, I hate having to say that. Note you can also say "Ask HomeSeer to".
I am a bit confused and that might be due to my inexperience with billion dollar company home automation solutions. Why would I need to send anything to a cloud to begin with? Why do I need to use a name like Cortana, Siri, Alexa etc at all? Why can't I just use Spud's Kinect plugin and call it a day? I can use any digitized voice for talkback, if I feel that I need my digital assistant to tell me they did something that I can see happened before they would finish telling me they did. But do I really need to hear all that "overhead noise" every time I want to turn on a light switch?
https://www.youtube.com/watch?v=XyN1udYNffI
Originally posted by DD1 View PostI am a bit confused and that might be due to my inexperience with billion dollar company home automation solutions. Why would I need to send anything to a cloud to begin with? Why do I need to use a name like Cortana, Siri, Alexa etc at all? Why can't I just use Spud's Kinect plugin and call it a day? I can use any digitized voice for talkback, if I feel that I need my digital assistant to tell me they did something that I can see happened before they would finish telling me they did. But do I really need to hear all that "overhead noise" every time I want to turn on a light switch?
And if all you want to do is turn on a light switch, the lowest "overhead noise" option is to just walk over and turn the light on yourself.
Originally posted by macromark View PostThis thread is about the HomeSeer Echo skill If you wish to use that, you'll need to follow the syntax and procedure. If you don't want to do that, there are plenty of other options with HomeSeer.
Well you have a valid point... this is an Alexa thread but whether in presidential rallies or HA interface forums, you will always have someone who doesn't see eye to eye with the candidate on the stage.
More importantly though, regardless of chosen user interface, I will need to make sure no one can get in the front or back door uninvited. I have been lax in that area.
By "overhead noise", I was talking about the audio responses from the digital assistants.
