HS3 Beta 3.0.0.300 Discussions
Tags: None
I heard this has a battery status fix in it. One person indicated it so far seems to have resolved reporting issues on one device model they had issues with. Any other folks try it and have good news?
Is there a linux version? I'm on .293 and it shows no beta available, .297 as the last GA available.
I updated mine by going to a command prompt and:
cd /usr/local/HomeSeer
./updatehs.sh 300
sudo reboot
I'm hopeful this fixes my battery issues - will let it run a couple of days first...HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by rmasonjr View PostI updated mine by going to a command prompt and:
./updatehs.sh 300
sudo reboot
I don't seem to have a "updatehs.sh" script on my machine... I have an "update.sh" but seems to expect a full archive name that already exists on the machine as a parameter, AND running it (with the .300 archive) in the homeseer directory wouldn't do much good, as it'd create a new subdirectory (so you'd have /usr/local/HomeSeer/HomeSeer - with the new version in the deepest nested directory.)
It sounds as if your updatehs.sh script does a wget (or curl) to download the specified version, and unarchives it from the parent directory? Is this something of your own creation, or perhaps something that used to exist in previous HS3 archives?
Can you share the script?
Gary
Originally posted by rjh View PostSee HS3 release notes for changes.
The previously released HS3 version on linux was 297. In addition to the listed changed items, it appears that the 300 archive also includes several image files that were missing from the linux archive (but where included in the Windows installer) such as those used for the "central scene" z-wave command class.
Originally posted by garyd9 View PostWow... this message confused me. "Command prompt" is a term I usually associate with Windows, not with linux, so I was trying to figure out why you were using forward slashes (and sudo) with windows. I had to stop and actually use my brain. It was scary.
Gary
Yup - here is the script - it just does a wget with the version number passed-in:
PHP Code:homeseer@RPi2 /usr/local/HomeSeer $ cat updatehs.sh
sudo rm hslinux_hs3_3_0_0_$1.tar.gz
sudo wget http://homeseer.com/updates3/hslinux_hs3_3_0_0_$1.tar.gz
sudo tar xavf hslinux_hs3_3_0_0_$1.tar.gz
sudo chmod +x install.sh
sudo ./install.sh
This does NOT appear to be fixing the problem completely. Please see the attached image showing the "last changed" for my "toy room window sensor battery", a log entry showing that the value was polled, and the configuration showing that the option which would prevent updating the timestamp NOT selected.
(Oddly enough, the second line shown in the log is polling for a garage door sensor, and the timestamp for THAT device did update.)
Here's the log entries for one of my wireless smoke alarms that shows the battery was updated on the Device screen last at 3:58:40 PM.
All is well here with the update...
Note that the Event I have there is a heartbeat even so I can track when the node has not communicated after a couple of hours. The fact that it is present in the log means that the Node called in to report at that time which not only reset the timer but allowed it to update the battery status. The Battery status only updates every 12 hours and each node appears to randomly report in to do it. It's not like the all report at 6PM and 6AM etc...
-Travis
I wish the release notes were published consistently for all versions.
I sent in a request for the release notes for .298 on November 3rd and was told they would be updated shortly... Still waiting...
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by Daweeze View PostHere's the log entries for one of my wireless smoke alarms that shows the battery was updated on the Device screen last at 3:58:40 PM.
Note that the Event I have there is a heartbeat even so I can track when the node has not communicated after a couple of hours. ...
(I had used this to work around the bug... I had one massive event with several OR's that would check if any battery levels were below 20%... and the existence of that event resulted in the timestamps updating.. I deleted the event in order to test this build.)
So far, since I installed 300 (and removed the above mentioned event), I've seen 7 non-listening devices have their battery status polled on wakeup. 4 of the 7 have had the timestamp updated. The remaining 3 have NOT had their timestamp updated.
It doesn't seem to matter if the devices are same/different models, z-wave plus or not, etc. It also doesn't seem to matter if I'm using the beta z-wave plugin (.95) or the older "release" version (.87.)
Originally posted by garyd9 View PostThis does NOT appear to be fixing the problem completely. Please see the attached image showing the "last changed" for my "toy room window sensor battery", a log entry showing that the value was polled, and the configuration showing that the option which would prevent updating the timestamp NOT selected.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View PostCould it be that it did not reply to the poll
To be more clear: with the options I currently have selected, there are no log entries for any poll replies unless a device value actually changes. I don't know of any logging option that would show non-changing replies in the HS log.
On the other hand, the timestamps for all my battery devices did update at least once each overnight. At least two devices had a timestamp older than the most recent poll. (In other words, at least two devices were polled more than once last night, and the most recent poll did not result in the timestamp being updated.) One of those two devices is about 10 feet from the z-wave smartstick+, and the poll was at a time where there was no other activity shown in the log (suggesting a low likelihood of z-wave collisions.)
This (last night) was with the released (non-beta) z-wave plugin (.87.) I seem to have better luck with that plugin for some reason.
More information...
With various extra logging enabled, here's a WORKING sequence I normally see when a non-listening device wakes up and HS polls for the battery (log entries are in reverse chronological order - newest on top):
Code:Nov-17 11:31:18 Z-Wave SmartStick+: Z-Wave Wake-Up 'No More Info' Notification sent to Node 45(Basement Garage Denise's Garage Door Sensor (Control Device)). Nov-17 11:31:18 Z-Wave ApplicationCommandHandler from node 45 HANDLING: COMMAND_CLASS_BATTERY Frame(7)=3 Nov-17 11:31:18 Z-Wave SmartStick+: Sending to node 45 (UnSecured) CC=COMMAND_CLASS_WAKE_UP Nov-17 11:31:18 Z-Wave SmartStick+: Device (Node 45) woke up and Poll Device for Basement Garage Denise's Garage Door Sensor Battery was successfully sent. Nov-17 11:31:18 Z-Wave SmartStick+: Sending to node 45 (UnSecured) CC=COMMAND_CLASS_BATTERY Nov-17 11:31:18 Z-Wave SmartStick+: Wake-Up Notification Processing for Node 45 (Basement Garage Denise's Garage Door Sensor (Control Device)) Nov-17 11:31:18 Z-Wave SmartStick+: Z-Wave Wake-Up Notification Received for Node 45
Code:// missing "z-wave wake up 'no more info' sent" line // missing applicationcommandhandler handling CC battery Nov-17 11:22:44 Z-Wave SmartStick+: Sending to node 16 (UnSecured) CC=COMMAND_CLASS_WAKE_UP Nov-17 11:22:44 Z-Wave SmartStick+: Device (Node 16) woke up and Poll Device for Main Toy Room Toy Room Window Sensor Battery was successfully sent. Nov-17 11:22:44 Z-Wave SmartStick+: Sending to node 16 (UnSecured) CC=COMMAND_CLASS_BATTERY Nov-17 11:22:44 Z-Wave SmartStick+: Wake-Up Notification Processing for Node 16 (Main Toy Room Toy Room Window Sensor (Control Device)) Nov-17 11:22:44 Z-Wave SmartStick+: Z-Wave Wake-Up Notification Received for Node 16
However, I don't understand why the log line stating "Z-Wave Wake-Up 'No More Info' Notification sent..." doesn't appear. I can see the lower level log entry showing that the COMMAND_CLASS_WAKE_UP is sent (which likely contains the "no more info" command.)
Rich, what can cause the z-wave plugin to NOT log "z-wave wake-up 'no more info'" line? Is it possible that somehow the thread handling the message exchange is terminating prematurely?
UPDATE:
I'm starting to think that either something is wrong with that particular sensor, or HS3 just doesn't like that particular sensor for some reason. Here's the logging from the latest "wakeup" from it: (Note that I had queued commands for polling the battery AND for changing the wake up time to 1 hour in order to get more logging data)Code:Nov-17 14:23:37 Z-Wave SmartStick+: Sending to node 16 (UnSecured) CC=COMMAND_CLASS_WAKE_UP Nov-17 14:23:37 Z-Wave SmartStick+: Device (Node 16) woke up and Poll Device for Main Toy Room Toy Room Window Sensor Battery was successfully sent. Nov-17 14:23:37 Z-Wave SmartStick+: Sending to node 16 (UnSecured) CC=COMMAND_CLASS_BATTERY Nov-17 14:23:37 Z-Wave SmartStick+: Device (Node 16) woke up and Set Wakeup Interval command was successfully sent. Nov-17 14:23:37 Z-Wave Successfully set wake up interval for node 16 to 3600 Nov-17 14:23:37 Z-Wave SmartStick+: Sending to node 16 (UnSecured) CC=COMMAND_CLASS_WAKE_UP Nov-17 14:23:37 Z-Wave Setting wake-up interval for device Main Toy Room Toy Room Window Sensor (Control Device) to 1 hours and 0 minutes. Nov-17 14:23:37 Z-Wave SmartStick+: Wake-Up Notification Processing for Node 16 (Main Toy Room Toy Room Window Sensor (Control Device)) Nov-17 14:23:37 Z-Wave SmartStick+: Z-Wave Wake-Up Notification Received for Node 16
Could I ask if there are other changes that are not on the release notes, I have seen this post by spud here http://forums.homeseer.com/showpost....&postcount=282 that suggests that there may have been changes to the MyHS interface to enable some plugins to pass through it (?) - would it be possible to get an idea of what these might be/mean?
