This should be the nail...
RCS Serial Thermostat
That's from the HS2 plugin, and those are the addresses for the thermostats I have set up so far. I have the ZCV4 and ZCV6. Basically, the first two thermostats or zones on each are set up. All addressing is sequential. Thus, the four zone, 1 and 2 are in use. On the 6 zone, the addressing starts at 5, so in that case 5 and 6 are in use.HS: 2.5.0.60
Environment: Virtual XP as guest in VMWare Server running under Win 7
Plug-ins: MLHSPlugin|RCS Serial Thermostat|UltraLog|UltraMon|
Misc: 303 Devices, 313 Events, 68+ Scripts
HSeer: 3.0.0.54
Plug-ins: BLGData|BLRF|BLRadar|BLRandom|BLSpeech
UltraM1G3|UltraECM3|UltraMon3|UPBSpud|Z-Wave
Misc: 148 Devices, 116 Events, 9+ Scripts (so far, still converting)
I might add, on the HS3 plugin, I setup two thermostats so far, just to keep it simple, with address of 1 and 2. Problem is, I see no addresses going out during the POLL that occurs.HS: 2.5.0.60
HSeer: 3.0.0.54
set up just one, without the hub... set to address 1 at the stat and enter as unit 1 in the plug-in ( If at all possible, I've been know to run wires down my hallway during testing :>) )
lets see what you get.. it should be exactly like mineUbuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Well, the thermostats technically connect to the zone controller, the zone controller in turn connects to a RS485 hub with a serial out. There really isn't a way to connect to a single thermostat. Although, later on, I'm going to try to remove the second defined thermostat and see if it'll possibly work with the thermostat that has an address of 1.HS: 2.5.0.60
HSeer: 3.0.0.54
ok.. looks like the info you are receiving is as per spec
just temps as per item 16 above
soo the correct info is going to HS
Did you set up different stats in the plug-in using stat #'s 1, 2 5 & 6 ?
post a snapshot of the plug-in config pageUbuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Originally posted by jstaab View PostWell, the thermostats technically connect to the zone controller, the zone controller in turn connects to a RS485 hub with a serial out. There really isn't a way to connect to a single thermostat. Although, later on, I'm going to try to remove the second defined thermostat and see if it'll possibly work with the thermostat that has an address of 1.Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Originally posted by gearyt View PostOK.. got it.. Plug-in is not parsing out the address..
must be being sent as HS2 is seeing it
long route to get back where we started...
[Settings]
PollInterval=20
BaudRate=9600
Debug=True
RefIDs=66|74HS: 2.5.0.60
HSeer: 3.0.0.54
Re: RCS Serial Thermostat
Originally posted by mhog View PostHaving the same issue with my RCS TR40. Did anyone put in a bug ticket?
Sent from my SCH-I545 using TapatalkHS: 2.5.0.60
HSeer: 3.0.0.54
Originally posted by mhog View PostGreat. Certainly let me know if you or HS need additional information to clarify or test with.
Jstaab- I am looking forward to this almost as much as I expect your are. You helped me some time back with the special RCS plug-in build to address the set point issues.
HSeer: 3.0.0.54
