Here's the scenario:
I have two Qubino Flush 1 relays and they're both reacting the same way.
S1 is connected to a Heath Zenith motion sensor that is set for one minute on both units.
If I walk into the beam's path the light comes on and stays on for one minute. Perfect.
If I manually turn on the light via HS3 it stays on until I turn it off, also perfect.
My wife asked for a separate switch so I added a Zigbee switch via JowiHue. If I press the switch on, the light comes on and stays on. Yeah!
However, if the light is on either from me turning it on in HS3 or from the zigbee switch being pressed AND I then walk into the beam it shuts the light off!
The motion sensor works correctly, because it does turn the light on if it's off. But why does the light turn off if it's on.
Worse yet, I just realized that if the light is turned off by the motion sensor as I just described, one minute later it comes back on by itself.
I realize that pressing the switch reports a "1002" value which does not show up in the log. So I use "Had its value set".
I think the problem is that since it has a value of "1002" the event is triggered even though it should only trigger by pressing the switch.
How do I fix this???
Here are my events for the zigbee switch:
