8 Way Wall controller not changing status
    I have a HAI 8 button wall controller that I'm trying to use to turn on a flag in HS3. When I push button 1, there is no status change in HS.
    The basic event says if Button 1 controller changes and becomes ON, then set goodnight mode flag on ON.
    If I'm in HS and turn on the indicator light, it lights up on the controller just fine. So there is communication.
    Any idea where to look?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    could you set the log level to debug, and capture the logs when you press this button.
    is this button associated with any Link in Upstart?
    could you send me your .upe file
    thanks
      Here is the debug. I pressed the button 1 controller on, then off again.
      I'll send the upe file separately.
      May-12 7:11:45 PM
      UPBSpud
      DEBUG PIM_SEND:: Pausing because last command expected a reply
      May-12 7:11:45 PM
      UPBSpud
      DEBUG PIM_SEND:: Message ID 474 confirmed sent successfully
      May-12 7:11:45 PM
      UPBSpud
      DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=474)
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: PIM ACK'd current message (ID=474)
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: ABOUT_TO_SEND[07140E04FF30A4 ]
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: Sending Message ID 474 to PIM, retry count=0
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: Extracted next message to send from queue (ID 474)
      May-12 7:11:44 PM
      UPBSpud
      DEBUG DEVICE[4]:: Confirmed request to set device to level succeedded -- updating internal state
      May-12 7:11:44 PM
      UPBSpud
      DEBUG UPB_MGR:: passing queueMessage for UPB message to media-adapter
      May-12 7:11:44 PM
      UPBSpud
      DEBUG UPB_MGR:: STATE_QUEUE:: Sending state query for device Office Light (4)
      May-12 7:11:44 PM
      UPBSpud
      DEBUG DEVICE[4]:: Got request to set light to non-normative level -- queueing status request to confirm
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIMADAPTER:: Confirmed message to device succeeded
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: Message ID 513 confirmed sent successfully
      May-12 7:11:44 PM
      UPBSpud
      DEBUG PIM_SEND:: UPB Device ACK'd current message (ID=513)
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIM_SEND:: PIM ACK'd current message (ID=513)
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIM_SEND:: ABOUT_TO_SEND[0A140E04FF2264FF014B ]
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIMADAPTER:: Confirmed message marked as being sent, timeout timer has 10000 millis left
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIM_SEND:: Sending Message ID 513 to PIM, retry count=0
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIM_SEND:: Extracted next message to send from queue (ID 513)
      May-12 7:11:43 PM
      UPBSpud
      DEBUG PIMADAPTER:: Got update on Confirmed message, but still not sent to PIM yet
      May-12 7:11:43 PM
      UPBSpud
      DEBUG UPB_MGR:: passing sendConfirmedMessage for UPB message to media-adapter
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
        fixed in version 3.0.0.18
          -Tim
          Way2 Call
          Elk M1 Gold
          UPB HAI switches
