Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HSTouch™
HSTouch™ Discussions regarding HSTouch touchscreen software for HomeSeer
  #621
Old January 31st, 2017, 05:03 PM
Jayh391 Jayh391 is offline
Seer Plus
Sonos Page
Dave
Would you be willing to share any or all of these? They are all FANTASTIC!!
Jay
Quote:
Originally Posted by DoubleDrive View Post
Hi all,
I've been lurking this thread for quite a while gathering ideas and trying to figure out how best to deploy my HSTouch screens. Thought it was time to post mine. Still a work in progress, but it's coming along quite nicely.
  #622
Old March 22nd, 2017, 01:11 PM
fungun's Avatar
fungun fungun is offline
Seer Master
Had some time off from work.
So I decided to get all my devices finally finished.
001.jpg is the Table Top model from homeseer.
002.jpg is my 7" tablet that is going bedside on the wall
003.jpg is my Laptop
004.jpg is my 10" tablet going on the wall in the Living room.
005.jpg is my 17" touchscreen hooked up to the HS computer
Tim
ps Yea I need a better camera.
FB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
“No, I’m from Iowa. I only work in outer space.” – Captain Kirk
  #623
Old April 18th, 2017, 08:37 PM
bwinning bwinning is offline
Viewer
Just started designing this over the weekend.. here's where I'm at so far:
Ignore the duplicates, it's still a work in progress
I didn't like how the drop downs looked so I made a page that looks like a menu, it opens when you press a page title
  #624
Old April 22nd, 2017, 02:38 PM
manxam manxam is offline
Seer Deluxe
That looks excellent! Where are you grabbing the icons from?
  #625
Old April 22nd, 2017, 03:52 PM
logbuilder logbuilder is offline
Seer Master
That looks really good. I like the white on black theme.
One function that I don't see are Scenes. This is the most used screen on my app. Scenes allow you to control a number of devices for a particular activity. I have 11 scenes currently. As example, I have a scene for 'Watching TV'. It sets all the lights appropriately including some in other areas of the house. Another similar scene is 'Watching TV While Eating'. Whole different set of light levels including some in the kitchen and the path to get there.
It is easy to do scenes. Create a virtual device for the scene. In the HSTouch app, have a button to turn on that scene device. I don't actually control the actual devices for the scene in the HST app. I have an event for each scene that is triggered when the virtual scene device turns on. In that event I control the devices needed for the scene.
That's my way of doing scenes. Real easy and the logic of the scene is within the event rather than in the app.
  #626
Old April 23rd, 2017, 11:56 AM
Viewer
Quote:
Thank you! I'm grabbing them from the noun project, can't beat $40 a year!
Thank you! That's part of phase two for me, I'm starting with getting all my devices in the system and working as expected, then I'm going to get the automation and scenes together. I appreciate the advice on the virtual device/events for scenes in HST, I learned the hard way that I should be using events for things in the app instead of programming buttons right to devices when I had to reconfigure all of the aton buttons.
EDIT: here's some progress on the room pages (with scene's included )
  #627
Old May 4th, 2017, 04:16 PM
Seer Plus
Quote:
Originally Posted by electron73 View Post
Yes that is correct. Picture 2 shows what happens when you tap the status light "Kitchen", Picture 3 shows when you then tap the breakfast nook (dimmer) device (controls pop up on the far right), Picture 4 shows what happens when you then tap the LED Rope (switch) device. So once the device selector on the left is open, you can tap any device on it and the appropriate control will show on the far right so you can control that device, then select the next one and so on...
I did that with a bit of an undocumented trick. That's why the whole project does NOT work on Android or Windows. Each version of the HS3Touch client has its own serious bugs and they all behave differently. My intended behavior with the selectors and control only works on iOS and it's closest to what I expected to happen when I designed it in the designer.
What you do is this: You have the dimmer control screen and the on/off control screen, both of them have the list of supported devices listed (just like in the sample project that ships with HS3Touch Designer. When you design your whole project for landscape and have one "screen" that controls dimming devices and you use a device selector and a dimmer is selected, that screen shows up (so far all standard). When you then create a new screen, make it PORTRAIT (even though the project is landscape) and now you define just a subgroup of devices in that screen and you call that screen from the main screen in your project, a device selector will show up, giving you only the devices provided in that "fake screen" to choose from but when you actually click one, the "fake screen" does not show up, instead the HS3Touch client skips to the next one that supports the device, in that case the dimming device controls...
So you have a MAIN screen with say for example one button Living Room Dimmers and one button Bedroom Dimmers.
You then create two fake screens with the wrong orientation and call one Livingroom and the other Bedroom. In the Livingroom screen under "supported devices" you enter Livingroom_Dimmer and in the other Bedroom_Dimmer. In the actual control screen with the slider, you put both, Livingroom_Dimmer and Bedroom_Dimmer.
Then in HS3 itself you go to all your living room dimmers and in the advances settings under device type enter Livingroom_Dimmer and for all bedroom dimmers same deal, enter Bedroom_Dimmer there.
Now on the main screen you call the fake Livingroom screen from one button and the fake Bedroom screen from the other. When you then touch the Livingroom button, a device selector will pop up, giving you only the livingroom devices, tap one and the actual control screen with the slider will show up, since it is the "next best" match for the device type "Livingroom_Dimmer".
Hope this makes sense
AWESOME find!
I have been trying to get a ceiling fan to work- its not ON/ OFF or DIMMING, any idea how to control a ceiling fan?
  #628
Old June 9th, 2017, 08:03 AM
Derek's Avatar
Derek Derek is offline
Seer Deluxe
Quote:
Originally Posted by Jayh391 View Post
AWESOME find!
I created virtual devices for High, Medium, Low, Off then created events that turn them on/off when the virtual device is turned on/off and buttons on HS touch that fire the events.
  #629
Old August 24th, 2017, 11:41 PM
morrisdlx's Avatar
morrisdlx morrisdlx is offline
Seer
My First Efforts
This is a series of screens designed to fit on a Fire 8 HD. I am using the Fire as a starting point for implementing multiple touch screen tablets at various places throughout the house.
  #630
Old August 25th, 2017, 07:48 PM
jpape's Avatar
jpape jpape is offline
Seer Master
Quote:
Looks good. I also use the HD8’s around my house. What font did you settle on for your screens?
  #631
Old September 3rd, 2017, 03:49 PM
morrisdlx's Avatar
Seer
Sorry for the slow response... forgot where I posted shots... At this point, I am using Ariel as a font.
  #632
Old September 3rd, 2017, 04:09 PM
ewkearns's Avatar
ewkearns ewkearns is offline
Seer Master
These are awesome projects. What software are you folks using to yield such a clean and polished look? What is the output? .html? .xhtm? or?
TIA
HomeSeer Version: HS3 Pro Edition 3.0.0.379
Enabled Plug-Ins:
  • 2.0.47.0: BLBackup
  • 2.0.22.0: BLUPS
  • 1.1.2.0: Device History
  • 3.6.5.0: Harmony Hub (Pending Purchase)
  • 3.0.0.104: HSTouch Server
  • 3.0.1.90: PHLocation
  • 3.0.6331.36036: UltraCID3
  • 3.0.5917.35093: UltraLog3
  • 3.0.6260.19461: UltraMon3
  • 3.0.0.76: weatherXML
  • 3.0.1.152: Z-Wave
  • 3.0.51: HS Touch Designer
  • 3.0.0.40 Z-Seer+
  #633
Old September 3rd, 2017, 04:44 PM
jpape's Avatar
Seer Master
Hmm, I have not tried Ariel as I did not think it worked on the HD8’s.
  #634
Old November 6th, 2017, 12:42 AM
tome10 tome10 is offline
Seer Deluxe
Towards the beginning of this thread is an iPhone build that the buttons were transparent to the background. The guy hasn't been on since 2012 or so, does anyone have anything like that they would be willing to share?
  #635
Old November 6th, 2017, 04:09 PM
_ThaNerd_ _ThaNerd_ is offline
Seer
Still working on mine:
Used on a Samsung s8
Main:
Lights :
Remote (still under construction):
  #636
Old November 11th, 2017, 08:20 PM
rkirstuk rkirstuk is online now
Seer
Quote:
Originally Posted by txbandit View Post
Here are a few screenshots from my HTC Diamond mobile phone. Unfortunately I couldn't get too detailed because It's for a cell phone. Will post up more when I get my touchscreens. Hope you guys like.
So cool !
Wish these were transferable.
  #637
Old Yesterday, 07:00 PM
Viewer
Quote:
Mine are transparent on both my iPhone 7 and my Google Pixel, just be sure to use PNG files that don't have a background. I get my buttons from the noun project (I have a paid sub).
Quote:
TIA
I'm just using HSTouch/HSTouchDesigner
  #638
Old Today, 12:34 AM
Seer
looks like a lot of work !
I need to build my system but hope I can get there !
HTML code is On
