Hey Jowi
I have been have a lot of issues with this hue Plugin i sent a tickit to homeseer folks and the pointed me to you. It keeps chashing HS3 saying Homeseer not working. i will post the log they sent back.
Also why i am here it keeps saying there is an upgrade Available for the bridge I tell it to do the upgrade But it never does.
2 I am having problems creating groups Once I create a group It either disappears Or does not recognize the group.
But here lays the main problem And keeps crashing HS3 Below is the log Let the homeseer guys sent back. i hope this can be fixed because this is the main reason i am upgreading to HS3.
Greg replied
Oct 27, 10:56pm
I would recommend disabling this plugin and see if this reoccurs. The debug log indicates this is the culprit. ie - HSPI_JowiHue.HueTools.UpdateStatusTimer() at HSPI_JowiHue.HueTools+_Closure$__._Lambda$__R75-3(System.Object)
You need to post this issue on the plugin authors forum so he knows about this issue.
Message: I have been have the problem with Homeseer 3 stopped working problem below is the las message i posted in the HS3 forum. but first my system profile can you help Current Date/Time: 10/27/2017 4:37:40 PM HomeSeer Version: HS3 Pro Edition 3.0.0.368 Operating System: Microsoft Windows 7 Ultimate - Work Station System Uptime: 0 Days 0 Hours 14 Minutes 42 Seconds IP Address: 10.0.0.218 Number of Devices: 66 Number of Events: 1 Available Threads: 400 License: Trial License: 0 User Name and Access Level: default (Admin) WAN IP Address: 76.107.12.205 Web Server Port: 8080 Location: (Latitude) 35.15 (Longitude) 90.05 City/State-US-Tennessee,Memphis,90.05,35.15 Enabled Plug-Ins 2.0.127.0: BLRadar 2.0.92.0: BLRF 2.0.1.0: JowiHue 3.0.0.36: X10 i rebuilt the the entire system including a fresh copy of windows 7 i am Attaching the windows event errors from windows you will need to be on a windows pc to read it but it looks like the HUE plugin is the problem also below is the same info in a text version Here is my system profile Current Date/Time: 10/27/2017 4:37:39 PM HomeSeer Version: HS3 Pro Edition 3.0.0.368 Operating System: Microsoft Windows 7 Ultimate - Work Station System Uptime: 0 Days 0 Hours 14 Minutes 41 Seconds IP Address: 10.0.0.218 Number of Devices: 66 Number of Events: 1 Available Threads: 400 Enabled Plug-Ins 2.0.127.0: BLRadar 2.0.92.0: BLRF 2.0.1.0: JowiHue 3.0.0.36: X10 - EventData An unhandled exception occurred and the process was terminated. Application ID: HS3.exe Process ID: 4856 Exception: System.OutOfMemoryException Message: Exception of type 'System.OutOfMemoryException' was thrown. StackTrace: Next Error Application: HS3.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.OutOfMemoryException Stack: at System.TimeZoneInfo.GetDaylightTime(Int32, AdjustmentRule) at System.TimeZoneInfo.GetIsDaylightSavingsFromUtc(System.DateT ime, Int32, System.TimeSpan, AdjustmentRule, Boolean ByRef) at System.TimeZoneInfo.GetUtcOffsetFromUtc(System.DateTime, System.TimeZoneInfo, Boolean ByRef, Boolean ByRef) at System.DateTime.ToLocalTime(Boolean) at System.DateTime.FromFileTime(Int64) at System.Timers.ElapsedEventArgs..ctor(Int32, Int32) at System.Timers.Timer.MyTimerCallback(System.Object) at System.Threading.TimerQueueTimer.CallCallbackInContext(Syste m.Object) at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers() at System.Threading.TimerQueue.AppDomainTimerCallback() Next Error HS3.exe 3.0.0.368 59c917e9 KERNELBASE.dll 6.1.7600.16385 4a5bdbdf e0434352 0000b727 12f8 01d34ed687410530 C:\Program Files (x86)\HomeSeer HS3\HS3.exe C:\Windows\syswow64\KERNELBASE.dll 3b373cba-bb51-11e7-8130-f4b7e2f8a944 Next Error Application: HSPI_JowiHue.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException Stack: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(System.Runtime.Remoting.Messa ging.IMessage) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Syst em.Runtime.Remoting.Proxies.MessageData ByRef, Int32) at HomeSeerAPI.IHSApplication.WriteLog(System.String, System.String) at HSPI_JowiHue.utils.Log(System.String, LogLevel) at HSPI_JowiHue.HueTools.UpdateStatusTimer() at HSPI_JowiHue.HueTools+_Closure$__._Lambda$__R75-3(System.Object) at System.Threading.TimerQueueTimer.CallCallbackInContext(Syste m.Object) at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers() at System.Threading.TimerQueue.AppDomainTimerCallback() Next Error HSPI_JowiHue.exe 2.0.1.0 59e4c857 mscorlib.ni.dll 4.0.30319.17929 4ffa561c c0000005 0032c882 1430 01d34eda460bb9b8 C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\51e2 934144ba15628ba5a31be2dae7dc\mscorlib.ni.dll 8073df14-bb51-11e7-8130-f4b7e2f8a944
Thank Tim Fraley
Greg replied
Oct 27, 10:56pm
Thank Tim Fraley
