Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old July 13th, 2018, 02:29 AM
Fellhahn's Avatar
Fellhahn Fellhahn is offline
Seer
Multi Channel Association
I'm trying to figure out why multi channel association isn't functioning correctly on a Qubino dimmer that supports the multi channel association command class.
Below is a screenshot showing the node information:
My understanding is that a multichannel association device should present with an "endpoint" option when configuring association groups, I've seen examples of this in other threads:
I also understand that on a multichannel association group node, association groups should be able to be configured from the endpoint itself, not just the root node.
Neither of this is proving true for me, when I select an endpoint (switch in this case) and navigate to the z-wave tab, the associations section is greyed out.
Also, when viewing the association group configuration on the z-wave tab of the root node, there is no "endpoint" option presented anywhere:
Any tips on what I might be doing wrong?
Is there an option I need to enable within HomeSeer to support multi channel association?
Do I need to be using a particular interface? I'm currently using a HomeSeer Smart Stick+.
- Michael
HTML code is Off
Need multi-channel camera system suggestions Rupp HomeSeer General Discussion Area 9 December 21st, 2015 10:24 PM
Aeon multi-sensor motion association ksum HomeSeer Z-Wave Plug-in 0 December 18th, 2013 12:02 AM
Multi Instance/Channel Devices, wish list bartbakels HS3/PRO Beta Releases 2 November 6th, 2013 12:33 PM
Homeseer and Multi-channel hadiesper HomeSeer Z-Wave Plug-in 4 March 14th, 2012 08:52 AM
Small amp for multi channel Bestgear UK/Europe 2 January 17th, 2009 07:47 PM
