Old July 13th, 2018, 05:22 PM
JimSpy's Avatar
JimSpy JimSpy is offline
Seer Deluxe
Circles System Down
I have an error message in my startup file:
7/13/2018 2:16:31 PM ~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. The requested address is not valid in its context
This is preventing my web interface from starting up.
My settings.ini has the following line:
gWebSvrPort=80
I've never changed it. The only thing I changed may be the USB port that the PLM is plugged into.
Any advice appreciated.
Old July 13th, 2018, 05:52 PM
keithj69 keithj69 is offline
Seer Plus
Sounds like something else is using port 80. If you put the ip of the hs machine does another site come up?
Old July 13th, 2018, 05:58 PM
jeubanks's Avatar
jeubanks jeubanks is offline
Seer Master
Did you install deCONZ on the same system?
Old July 13th, 2018, 06:13 PM
rprade's Avatar
rprade rprade is online now
OverSeer
In addition to what was written above, what O/S are you running? If Windows 10, it is possible an update may have started the World Wide Web Publishing Service. It listens on port 80. Launch services.msc and look for that service. If it is running, change it to "Disabled" and stop the service.
Randy Prade
Aurora, CO
Prades.net
Old July 13th, 2018, 07:34 PM
JimSpy's Avatar
Seer Deluxe
Quote:
Yes, as a matter of fact, this PC comes up - again! Somehow it has given itself two IP addresses, 192.168.1.121 (which is correct for running HomeSeer) and x.x.x.145 (I have no idea).
Wait...now when I run IPCONFIG I only see the 145.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Speiser's>ipconfig
Windows IP Configuration
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Wireless LAN adapter USB Wireless Dongle:
Link-local IPv6 Address . . . . . : fe80::512e:d475:1a1c:eb6c
IPv4 Address. . . . . . . . . . . : 192.168.1.145
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
Ethernet adapter Local Area Connection:
Tunnel adapter isatap.{2B32391B-ED70-4B2F-AF34-37C68C3E4839}:
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Tunnel adapter isatap.{D075AF35-1327-4029-B9E0-E522D1E5B4A6}:
Tunnel adapter isatap.{F28B334E-C8A8-4007-9998-E72C2FE9BC5D}:
C:\Users\Speiser's>
Old July 13th, 2018, 07:35 PM
JimSpy's Avatar
Seer Deluxe
Quote:
I have no idea what that is (except rat poison...) so I'll assume the answer is no.
Old July 13th, 2018, 07:36 PM
JimSpy's Avatar
Seer Deluxe
Quote:
Nope, still on 7. Someday I'll upgrade...but not today!
Old July 13th, 2018, 08:46 PM
Seer Plus
Quote:
Check services as suggested.
Check the settings on your network card.
Correct the ip if wrong, reboot test.
If assigning a static ip, worse case scenario, open a command window and type "netsh ip int reset ' No quotes. You need to reboot and re input your network settings. Record the settings first if you do not do this everyday.
Old July 14th, 2018, 12:16 AM
JimSpy's Avatar
Seer Deluxe
I don't see a suggestion about services.
Old July 14th, 2018, 02:20 AM
ShimmerNZ's Avatar
ShimmerNZ ShimmerNZ is offline
Seer Deluxe
run resmon select the network tab and then click the arrow on the right to give you the list of processes running on what port. Assuming something else is running on port 80 that will tell you which process/app it is.
Old July 14th, 2018, 03:18 AM
JimSpy's Avatar
Seer Deluxe
OR....just reboot the damned computer. It works just fine now. I forgot how finnicky the USB ports on my server are. If you change what goes in what, it takes a couple of reboots to make them comfortable in their new homes.
Secure from General Quarters, cancel red alert. Thanks to all.
HTML code is Off
System crashed and seriously messed up my system jonjonbear Insteon Plug-in (Mark Sandler) 4 December 9th, 2015 12:07 PM
New HS3 System rmasonjr General Home Automation Hardware Discussion 55 January 9th, 2015 05:58 PM
Arm system jacpot UltraM1G HSPI 2 November 25th, 2008 02:21 PM
Which OS is best for a new system? jgoos1@san.rr.com HS2 / HSPRO 1 March 8th, 2008 06:32 PM
New System BringerOD HS2 / HSPRO 11 September 11th, 2005 09:33 AM
