I have 2 EcoLink TLT-ZWAVE2 sensors.
One on each garage door.
Both sensors work reliably to report the state of the garage door.
But one does not report the battery level.
The other occasionally reports the battery level. Once every 3 or 4 days even though both have their battery polling set to 12hrs in HS3.
The one that never reports is farther away from my ZeeS2.
What I have found out is that the EcoLink goes to sleep too quickly.
The one that reports battery occasionally is able to reach the ZeeS2 directly without having the route thru the Z-Wave mesh network.
The other one is just 12' further away but it is never able to reach the ZeeS2 without routing.
So if your EcoLink isn't reporting battery - it is because EcoLink needs to fix their firmware! I sent them an email detailing the problem so we'll see if they respond.
