My guess is that they are asking about access to the breaker because they are used to poping breakers in residential (and even commmercial) buildings during shoots and want to make sure they have easy access to reset them. You've mentioned that you have had photographers in your place before, but I think that you'll be suprised at how much lighting gear a film crew needs and will stage ALL OVER your loft.
A photographer who is shooting stills will only need to light specific areas and will rely much on strobes that don't require nearly as much power since they charge. A film crew will use a bunch of different lighting that uses considerable power and has to remain on while setting up and shooting. The camera gear itself is now fairly small and will most likely be battery operated... it's the lights they are worried about!
If you plan to supply power from another source, you may ask the producer what type of capacity he will need to make sure it's up to the demand.
Cheers,
Paul
Cheers,
Paul
