I received my unit 4 months ago but had no time to install it when I received the unit. I played with it and even surfed the web with it . Cool. Now, when I want to finial install the unit, the Icecream droid lights up around the edges and stops at it's right arm. It does not fill in the body to display the Icecream sandwich. I changed the network cable, and POE adapter. It is Android OS 4.0, Kernel 3.0.8 and Build 1.5.2. I get this information at least on boot. Any solutions?
Icecream does not boot
Boot problem fixed - Received new unit (last one from Homeseer)
The problem with the TouchScreen not booting was a bad unit. I received the last unit from Homeseer. The units are still available from the manufacturer Shenzhen Sibo Industrial & Development Co., Ltd.. Cost: 9 inch tablet $166 with metal clips or $168 with metallic enclosure + $44.10 shipping for one 'sample'.
Re-flash worked for me with this problem
I had a similar problem to what you were describing but the re-flash process described in http://board.homeseer.com/showthread.php?t=165539 worked for me. Your mileage may vary.
