DESCRIPTION
Plug-in for the Xanura/Marmitek/Haibrain PMIX35, CTX15 and CTX35 A10 interface. Full support for most European A10/X10 modules including last known dim status, status request, shutter support and other specific Xanura features.
REQUIREMENTS
INSTALLATION
There are no additional software requirements. The plug-in can be installed from the HS3 updater, and can be found under the section “Lighting & Primary Technology”.
CONFIGURATION
After installation and starting the plug-in, go to the configuration page. They are five tabs:
TROUBLESHOOTING
If anything doesn’t work, you can try one the following:
REQUIREMENTS
- This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions
- .NET Framework 4.5 or later, or mono 4.x needs to be installed on your Homeseer machine
- A Xanura/Marmitek PMIX35, CTX15 and CTX35 A10 interface
INSTALLATION
CONFIGURATION
- Interface settings: Select your interface type, and leave the Transmit Voltage to max unless you have specific requirements. Leave the send position to 0 degrees, otherwise you will have problems with the interface.
- Housecodes: Select the housecodes the plugin should respond to.
- Device Settings: Select device properties. Hover over the settings to get additional info.
- Debug: Leave all settings to Off, unless you want a LOT of information in the logfile.
- Support: How to get support and how to donate
TROUBLESHOOTING
- Make sure the interface works with the PMIX35 utility.
- Check if the correct COM port is selected.
- Check if the Interface settings are correct (see Configuration)
