Hi, fairly new to Insteon but have lots of remotes & modules up and running with HS3, along with z-wave and Philips Hue.
I'm trying out a keypadlinc but can't seem to get it to do anything in regards to triggering events. I didn't want to go through and program any groups since not all (in fact none) of the devices it's going to control are Insteon; they're z-wave switches and other modules.
So basically it's a glorified 8 button remote control mounted to the wall.
But I can't seem to get it to do anything once it's set up. Here's the setup (and I've already tried a factory reset and repogram and it does the same thing):
Device Link Table
Link #5 Load has local control reporting to HomeSeer
Link #1 Button A is controlled by HomeSeer using RF Dongle Group #0 (i2CS Registration Link) - On Level: 0%, Ramp Rate: .5 Sec.
Link #2 Button A is controlled by HomeSeer using RF Dongle Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
Link #4 Button A is controlled by HomeSeer using RF Dongle Group #1 (Button Control Group) - On Level:
, Ramp Rate:
Link #6 Button A is controlled by HomeSeer using RF Dongle Group #254 (HomeSeer All Devices Group) - On Level:
, Ramp Rate:
Link #7 Load is controlled by HomeSeer using RF Dongle Group #0 (i2CS Registration Link) - On Level : On
Link #3 Load is controlled by HomeSeer using RF Dongle Group #9 (Button Control Group) - On Level :
Dual-Band KeypadLinc Dimmer Channels
Shows all eight buttons plus a ninth "load". I am not using the red wire on this so I don't care about the load option.
In the log (even under the debug level) no entries are recorded for button presses. Usually you'd see something like "Button A pressed ON" or something but nothing here.
Any thoughts?
Device Link Table
, Ramp Rate:
, Ramp Rate:
Any thoughts?
