Help with RS-232 Send Command
    I could really do with a wee bit of a pointer, I've been trying to control the volume on a Allen and Heath DR66 via RS-232, by having two buttons on an x10 remote as (VOL+) and (VOL-)
    The problem is that the strings you send to the DR66 have to end in the value you want for the volume (0-127), so there is no incremental (volume up and volume down) command!
    That means I have to store the current volume (0-127) as a varible in script and then pop it into the end of the string with either a + or a - to raise or lower volume.
    This is how I have seen it done in AMX programming for Allen and Heath protocol to raise the volume in +2 steps (where oup1Level is the stored value)
    IF(oup1Level <127)
    oup1Level = oup1Level +2
    SEND_STRING DR66,"$B0,$63,$01,$62,$1B,$06,oup1Level"
    Anyone have any ideas how I could do the same thing using SendToCOMPort?
    Here's how I'm getting on so far:
    I have written variables to the startup script for all my volume levels
    hs.SaveINISetting "settings","vol1","75","my_settings.ini"
    hs.SaveINISetting "settings","vol2","75","my_settings.ini"
    hs.SaveINISetting "settings","vol3","75","my_settings.ini"
    hs.SaveINISetting "settings","vol4","75","my_settings.ini"
    hs.SaveINISetting "settings","vol5","75","my_settings.ini"
    hs.SaveINISetting "settings","vol6","75","my_settings.ini"
    This works fine, next I use this script to send the commands to the DR66 (this is Volume Up on CH1)
    sub Main()
    dim volume
    volume = hs.GetINISetting ("settings","vol1","","my_settings.ini")
    volume = volume + 2
    hs.OpenComPort 1,"9600,n,8,1",0," "," "
    hs.SendToComPort 1, CHR(190)
    hs.SendToComPort 1, CHR(239)
    hs.SendToComPort 1, CHR(03)
    hs.SendToComPort 1, CHR(06)
    hs.SendToComPort 1, CHR(00)
    hs.SendToComPort 1, CHR(186)
    hs.SendToComPort 1, volume
    hs.SaveINISetting ("settings","vol1",volume,"my_settings.ini")
    hs.CloseComPort 1
    end sub
    Now, it works ok up until I try to save the "dim volume" back into the INI, then I get the error:
    Error 1044:Cannot use parentheses when calling a sub in line 23
    anyone know who to put this in with the right syntax?
    Thanks!!
      Got it!
      It was the brackets round the SaveINISettings parameters, somehow it liked it at the start but not for the second time round
      Happy days
        You can save a few lines of code by concatenating this into one string if you want:
        hs.SendToComPort 1, CHR(190) & CHR(239) & CHR(03) & CHR(06) & CHR(00) & CHR(186) & volume
          Nice one! thanks for the tip!
