I installed HS 3.0.0.152 two days ago and for the first time since I tried to use HS touch to turn on some sprinklers. It did not work. So I tried to use the web interface on the computer which HS is installed on, again nothing worked. I turned on debugging and this is what the log is showing each time I try to turn on or off a sprinkler valve.
Jan-19 14:30:46 EZFlora Error An unexpected error occured in the SetIOMulti() function/subroutine: [System.IndexOutOfRangeException: Index was outside the bounds of the array. at HSPI_EZFLORA.HSPI.SetIOMulti(List`1 colSend)]
Jan-19 14:30:46 EZFlora Debug Entered SetIOMulti() subroutine.
Jan-19 14:30:46 Device Control Device: Irrigation Front Yard Front Parking to Off (0) by/from: CAPI Control Handler
Jan-19 14:30:41 EZFlora Error An unexpected error occured in the SetIOMulti() function/subroutine: [System.IndexOutOfRangeException: Index was outside the bounds of the array. at HSPI_EZFLORA.HSPI.SetIOMulti(List`1 colSend)]
Jan-19 14:30:41 EZFlora Debug Entered SetIOMulti() subroutine
The valves activate when I use an insteon keypad link to turn them on manually. The system worked fine prior to the upgrade. I am able to control all of my other devices okay after the update.
Has anyone else had a problem? Any help on this issue would be greatly appreciated. I am leaving on a trip and would really like to be able to water my lawn automatically I am gone.
Windows 8.1 EZflora 2.0.0.1
