I have posted 2.0.5 of the plugin.
I had to change the IR code delimiter in the INI file so you will have to re-add all of your codes again. I am sorry for this but I had no choice.
The devices should load fine but no codes will load. Just re-add all codes and learn them again and you should be fine.
NOTE
If you are using 2.0.5 or above for the first time then ignore this.
NOTE
