Blade, I believe that there a issue with this plugin on restart On HS 409. When you restart HS it will not find the stat. You need to go to options and initialize the thermostat so that the plug-in could find it.
I believe the problem is caused by HS. The new ver. Starts up all the plugin at startup first then HS. I have tried several time and it always fail. At least for me. It just a heads up....
