HS3 PRO Linux Help
    HS3 PRO Linux Help
    I am new to homeseer. I have just built my system using Ubuntu Minimal v16. I followed a few posts on here about installing on linux but i keep having an issue when trying to run homeseer with the ./go command.
    I keep getting the following:
    root@Homeseer:/home/homeseer/HomeSeer# ./go
    Unhandled Exception:
    System.TypeLoadException: Could not load type of field 'HSConsole.My.MyProject:m_ComputerObjectProvider' (0) due to: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. assembly:Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a type:<unknown type> member:(null) signature:<none>
    [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type of field 'HSConsole.My.MyProject:m_ComputerObjectProvider' (0) due to: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. assembly:Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a type:<unknown type> member:(null) signature:<none>
    Which version of Mono do you have installed? Also make sure to install mono-vbnc.
      Use this guide to install Mono on Linux.
      Mono Download and installation Guide
        I had mono complete, added mono-vbnc and everything is perfect. Thought I better reply just to let everyone know how these threads can really help many people who don't even leave a comment. Be aware of that, you are a great help!
