UltraLog for HomeSeer 2.2:
UltraLog is a HomeSeer 2 plug-in that allows you to direct HomeSeer log events to an underlying database. In addition, UltraLog can listen for syslog packets and insert syslog events into the underlying database.
Other Features:
Installation:
- Written in VB.Net 2005, 100% managed code.
- Multi-threaded.
- Tested on Microsoft Windows XP SP2 and Windows Vista Premium.
- Free 30 Day Trial
- Available through the HomeSeer store
Other Features:
- Logs all HomeSeer log events to a database in real-time.
- Supports HomeSeer triggers based on text or regular expression matches on HomeSeer log or syslog events.
- Web page supports query, filter, status and options.
- Currently supports Microsoft Access (database included), Microsoft SQL 2000 and Microsoft SQL 2005.
- Ability to specify custom OLEDB connection strings.
- Ability to save and recall SQL queries.
- Ability to purge database records after a specified number of months.
- Ability to open and close database connections while plug-in is running.
- Debugging output to troubleshoot database connection issues.
Installation:
- Installed via HomeSeer 2 Updater
- Restart HomeSeer2, then select Setup > Interfaces > UltraLog
