Thanks. It looks like this is a common issue and I don't know if there is a fix for constant pairing. It tried this from a website here https://discussions.apple.com/thread...rt=0&tstart=0:
I realise this is an old topic, but it seems everyone has the wrong band-aid fix.
The correct fix is as follows:
The issue is that Windows doesn't recognise the iPhone as a Bluetooth Peripheral Device and cannot find the correct driver to download and install.
Follow the following steps:
- First, you need to install the appropriate 'Windows Mobile Device Support' software for your version of windows (32 and 64 bit versions have different files to download). It may look like it didn't install in Windows 7, but that's ok. It did.
- Turn on the bluetooth discovery mode on the iPhone.
- Select 'Add a Device' in Devices and Printers, follow the instructions to connect and enter the 8 or 9 digit key into your iPhone.
- Your iPhone should be found and automatically install all the software and drivers except for the Bluetooth Peripheral Device driver.
- In Devices and Printers, right click the iPhone, select properties, and then the hardware tab.
- The first device function should be 'HID-compliant consumer control device. Ensure it's selected.
- Select Properties, and in the next window select 'update driver'
- Select 'Browse my computer for driver software'
- Select 'Let me pick from a list of device drivers on my computer'
- Select 'Bluetooth Radio' from the left hand side listing
- In the next window, select 'Microsoft Corporation' on the left, and 'Windows Mobile-based Device support' from the right side.
- Install this option, clicking through the warnings and accepting this option.
- Now you have the device driver installed, and your iPhone will be connected via Bluetooth when you need to pair it - great for file transfers and internet access without turning the radio on.
I hope this helps. This is the proper fix. Not the 'pressing two keys at the same time' or unchecking the option that only allows some features to be used.
