I don't use Cumulus MX but this may assist you: http://wiki.sandaysoft.com/a/Simple_...tup#Cumulus_MX
Jon00 Cumulus/weeWX Weather for Homeseer 3 & Homeseer 4
Originally posted by jon00 View PostI don't use Cumulus MX but this may assist you: http://wiki.sandaysoft.com/a/Simple_...tup#Cumulus_MX
Wind Direction Device String
I am trying to use Select Case to parse out the wind direction and replace with the full text.
'Select Case hs.DeviceString(533)
'Case "SSE"
'Windir = "South South East"
'Case "SE"
'Windir = "South East"
'Case Else
'Windir = hs.deviceString(533)
I can't get it to work. Even thought the device string is "SSE", there appears to be the graphic and perhaps hidden text.
I can't open the .vben script to see how the device string is being parsed.
Any hints?
DSteiNeuroDSteiNeuro
HS3Pro
Enabled Plug-Ins
I just installed and tried accessing my realtime.txt file. However, the data isn't stored there. That file exists but isn't updated by the software. Apparently the data is stored elsewhere possibly the \data directory which has lots of files.
I use Cumulus 1.9.4 and everything displays just fine in the Cumulus software. Where should I point the plugin please? Or is there something else I need to so.
I re-read parts of this thread and found the answer by @mworsnop. That certainly was buried.
I have the realtime file info displaying, however the order of items seems wrong. Since it's a bunch of comma separated data, how can I tell what's what?
For instance, I see "Rain Today" as 0.0F which is obviously a temperature reading. There are many other pieces data that are attached to the wrong piece of display wording.
I cannot see how the order can change as the file has a fixed format. The details of the file structure can be found here: http://wiki.sandaysoft.com/a/Realtime.txt
It seems that the very first realtime.txt file was scrambled. I let Cumulus run for awhile and the next file yielded good values. Thanks.
To see if I understand this correctly, if I only want a few virtual devices, I need to have the ini file look something like this??
[Device8]
DeviceName="Temperature Low"
ImageName="ThermometerLow.png"
DeviceText="<#tempTL> ° at <#TtempTL>"
DeviceValue="<#tempTL>"
[Device9]
DeviceName=""
ImageName=""
DeviceText=""
DeviceValue=""
[Device10]
DeviceName=""
ImageName=""
DeviceText=""
DeviceValue=""
[Device11]
DeviceName="Dewpoint"
ImageName="Thermometer.png"
DeviceText="<#dew> ° <#tempunitnodeg>"
DeviceValue="<#dew>"
etc. All the device numbers need to exist to match the fields in realtime.txt but if they're just quotes then the virtual devices don't get created.
Devices have to be sequential in the ini file and any gaps will prevent further devices from being displayed. Therefore delete everything you don't want and the rename the device headings in order i.e. [Device1],[Device2],[Device3] etc.
Once done, delete all the original virtual devices created and let the script recreate them again.
I'm a bit confused. Here's a portion of what I have and only Device 1 gets created. I have more definitions further down, but you get the idea.
What am I missing?
[Info]
Version=1.0.8
[Settings]
Filepath=c:\cumulus\realtime.txt
[Device1]
DeviceName="Updated"
ImageName="Timedate.png"
DeviceText="<#date> <#timehhmmss>"
DeviceValue=""
[Device2]
[Device3]
[Device4]
[Device5]
[Device6]
[Device7]
[Device8]
[Device9]
[Device10]
[Device11]
[Device12]
[Device13]
[Device14]
[Device15]
[Device16]
[Device17]
DeviceName="Wind Direction"
ImageName="Compass.png"
DeviceText="<#currentwdir>"
DeviceValue=""
