Looks good Marc!
Web page builder for Homeseer 3 & Homeseer 4
Web page builder on iOS 9.3
Jon, Web page builder seems to hang halfway through the page load on iOS9.3 on my iPad. Has anyone else reported this?
Steve QHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
Dedicated Event Setting in Web Page
Hi Jon,
Is it possible to display an existing preset EVENT in the web page and be able to edit the Events on this webpage?
For example: I have a manually trigger "Event" which will turn on some of the lights. Can I made the web page show this event only and be able to change the event setting?
Chin
As the page is generated by Homeseer there is not much you can do with it. If you use my Links utility, you can disable most of the links on the page.
You can embed this page within web page builder.
Perhaps it would be better to find out what you are trying to achieve?Last edited by jon00; March 30, 2016, 10:02 AM.
Basic failing with [device...] references - any help?
Jon00/all:
I'm trying to get this app to work. I can use the reference '[device,176]' which is the device reference - works fine. But when I try to use the name, it does not appear to process it '[device,"test1"]'. Am I doing something wrong - should [device...] be able to do device name resolution? I've also tried adding room and/or floor to the reference (this is the only device in this test system)....
Thanks for any help
