Jon00 Dashboard for Homeseer 3 & Homeseer 4
Not that I know of. HTML5 compliance has been asked many times before (Search the board for "HTML5 HSTouch")
All the png conversion work is done by the wkhtmltoimage file. Can you check in task manager that this runs when the widget updates. It would be best to set your updates using a 15 second timer for this test.
Originally posted by jon00 View PostNot that I know of. HTML5 compliance has been asked many times before (Search the board for "HTML5 HSTouch")
BUT still no PNG...
Could it be: the whole "dashboard" folder is marked as "read only"... EVen if I unpin it, it goes back to "read only" mode...
Originally posted by jon00 View PostAssuming you are on Win10, did you update from a previous version of Windows? If so, there are numerous posts on the web about permission issues where as an administrator account cannot write to files and folders. It appears that this gets screwed during the upgrade process.
will come back
reading the following: since Homeseer is nastalled in windows 10 "Program files" folder, it asks and needs administrative privileges... no way around it...
I wonder if that is true..??
playing with the idea to use another copy of "wkhtmltoimage" somewhere outside from Program folder... also to save files somewhere outside and then HSTOUCH to grab them and update...
What do you think?
Any command synopsis?Last edited by simon_bagola; July 19, 2016, 03:32 PM.
These are the settings for one device and it's not creating a png file. What am I doing wrong?
[Device7]
Timer=2
CreateVD=2
DataMode=0
Data1=$dva:PHLCBA[516]IC
Data1Multiplier=
Name=Battery Level
Title=Battery Level
Title1=
Width=270
Height=100
MinValue=0
MaxValue=100
Type=7
Options=411+203+602
Effects=3
CreatePng=1
