I tried installing the IsSpeaking plugin and it installed with no problems, but none of my hs.speak commands will work (which means there is no speaking happening). When I remove the plugin and restart HS, my speaking works fine again.
Anyone else having this problem? I am using HS 1.7 and the newest IsSpeaking plugin in the updater.
I have removed the plugin until I figure out why it is causing this.
