Update: A last second change I made before releasing .04 caused X10 traffic to be ignored. It was part of my test-bed that got mixed in with the release code.
It has been fixed in this .05 release.
Jon
Changes:
1) More X10 updates. Preset dimming confirmed working with switchlinc and other devices. X10 "streamed" dimming now working, although the SDM sends the commands out much slower than most other interfaces, causing the dimming to be sloooooooow. SDM updates should help resolve this.
2) Polling has changed. Since the SDM currently goes down when a device can't be reached the method of polling has been changed. Polling is now more of a background task, the results are posted to HS as soon as they come in from the SDM.
3) More robust error reporting and handling. The startup sequence has been changed so that it is clear if the SDM is not installed/working as compared to the actual Insteon interface not being installed or working. The configuration page now indicates any failure status.
4) Various smaller bug fixes.
Installation:
Install the updater version, INSTALL THE SDM!, then download the attached ZIP file and place the files in your HomeSeer directory.
Jon
Jon
Changes:
Installation:
Jon
